Kz750 LTD 1981
+ Reply to Thread
Results 1 to 7 of 7
Thread: Kz750 LTD 1981
  1. #1
    Join Date
    Jun 2012
    Posts
    2
    Default Kz750 LTD 1981
    I just sent my son home with his first KZ...nice bike, just cleaned the carbs, gave it a tune and it is running beautiful. Trouble is, he's 200 miles away and telling me the bike has begun leaking gas out a tube that falls directly in front of the rear wheel. My first thought was the carb overflow tubes but he says it's not those. He said it seemed to be coming out of a drain line from the bottom of the air filter box. After taking the filter out, he found a small pool of gas in there. Can anybody tell me why gas would be backing into the air filter box? Is there another line that might be bringing gas in to the filter? Thanks for any help.
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #2
    Biker Chef BTK Expert sheldonbourgeoi's Avatar
    Join Date
    Jul 2008
    Location
    Victoria, B.C.
    Posts
    987
    Default Re: Kz750 LTD 1981
    Could be a stuck float valve, worn float valve. Float level heights may need to be adjusted as well.
    A bad fuel petcock will also let gas past while the bike is sitting, and it will either back up out the carb overflow tubes, or get past the float valves into the cylinders. Then it gets past the piston rings, contaminating the crankcase oil. Can also cause the bike to hyro-lock on start-up, which could lead to a bent con-rod.
    1984 GPz 750
  4. #3
    Uncle Bob's Love Child BTK Intermediate LTD fan's Avatar
    Join Date
    Oct 2011
    Location
    South Jersey
    Posts
    262
    That year doesn't have a vac operated diaphragm so fuel will flow unless it is turned to off. Most likely a float valve.
  5. #4
    Forensic Bug Splatter Analyst BTK Expert martin-csr's Avatar
    Join Date
    May 2011
    Posts
    1,594
  6. #5
    Join Date
    May 2011
    Posts
    1,594
  7. #6
    Join Date
    Oct 2011
    Location
    South Jersey
    Posts
    262
    His bike has the same vacuum petcock as my 81 KZ650-CSR.
    I had a 80 and 81 kz750 and 650csr (Two bikes) and neither had the diaphragm petcock valve. Still have the tanks if anyone's interested.
  8. #7
    Join Date
    Jun 2012
    Posts
    2
    At first glance at my own 83KZ 750 I thought it was the carb overflow tube also but the tube I believe my son is talking about, and I have two of them, is coming from near the top of the carbs, right in between the two on either side.
    Also, I don't believe his bike has the shutoff for the gas line, I might be wrong but if my recollection is correct he does not.
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Questions about the seat for a 1981 kz750 LTD H2
    By shortys513 in forum Vintage Motorcyle Info
    Last Post: 10-05-2010, 06:21 AM
  2. 1981 kz750 LTD problem
    By carlos750LTD in forum The Mechanics Corner
    Last Post: 09-17-2010, 10:53 PM
  3. 1981 KZ750 LTD
    By CFundak750LTD in forum Vintage Motorcyle Info
    Last Post: 05-07-2010, 12:41 PM
  4. Kawasaki KZ750 Ltd H2 1981 owners manual request please
    By biker_gal_uk in forum Vintage Motorcyle Info
    Last Post: 06-21-2009, 03:16 PM
  5. 1981 kz750 ltd valve shimm blues
    By circle_u in forum Vintage Motorcyle Info
    Last Post: 09-08-2008, 09:49 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
