BTW there are several Recalls on Kawasaki listed in the back of Cycle World, July 2004...
NHTSA Recall No. 04V008
2003-04 Kawasaki Vulcan 1500Classic,
2003-04 Vulcan 800 Clasic, 2004 Vulcan 800
Number of units involved 2082.
Problem: On certain motorcycles, the acceleraror-pump diaphrams may be damaged due to excessive assembly clamping pressure, which can allow fuel to leak from the pump's actuating-rod area. Fuel leakage in hte presence of an ignition source could result in a fire.
Remedy: Dealers will replace the acceleratorpump diaphram. Owners who do not receive this free remedy within a reasonable time should contact Kawasaki at 949-770-0400.
NHTSA Recall No. 04V023
2003-04 Kawasaki Vulcan 1500, 2003 Velcan 1600
Numbers of units involved 6958
Dates of Manufacture: June'02-Feb.'03
Problem: On certain motorcycles High oil pressure upon cold start-up can deform the oil-filter cartridge, allowing oil to leak past the O-ring, possibly causing a loss of traction nd a crash.
Remedy: Dealers will replace the oil filter. Owners who do not receive this free remedy within a reasonable time should contact Kawasaki at 949-770-0400.
LinkBack URL
About LinkBacks
ZX-2R
