mean streak exhaust
+ Reply to Thread
Results 1 to 5 of 5
Thread: mean streak exhaust
  1. #1
    Join Date
    May 2006
    Posts
    4
    Default mean streak exhaust
    I have a '04 mean streak with stock exhaust. I have installed a k&n air filter and want a little more volume on the exhaust. Someone said I should drill a 1/2 inch hole thru the baffles. Ideas? Thanks
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #2
    Extreme Forum Supporter Extreme Forum Supporter uechi kid's Avatar
    Join Date
    Oct 2005
    Location
    Antioch, Ca.
    Posts
    2,482
    If you want to keep the stock lokk debaffle them. Take a look at this.
    http://homepage.mac.com/lydanynom/iMovieTheater5.html
    "Carpe Diem"
    04 M95
    08 Royal Star Venture
  4. #3
    Join Date
    May 2006
    Posts
    4
    Great tip! I may try the drill method first, but appreciate your help.
  5. #4
    Join Date
    Nov 2005
    Posts
    12
    Quite a few guys on this forum with Meanies have debaffled them. I did mine not too long ago. If you do a search either of "debaffled Meanie" or "debaffled" you should find the instructions. There are 3 screens in the pipes that you can cut out. The first 2 you can reach with a 1/2" hole saw. The last you will need a 12" extension. I also recommend using a guide rod when removing the first 2. Deniska helped me out.
  6. #5
    Join Date
    May 2006
    Posts
    4
    Have you attempted to use an aftermarket baffle after debaffling, or are you happy with the raw debaffled sound. Also, did you need to make any other adjustments as a result. I have already put in a K&N filter.
    Thanks
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Replies: 7
    Last Post: 10-21-2005, 11:39 PM
  2. Quietest Exhaust for a Mean Streak
    By Illus in forum Kawasaki Cruisers
    Last Post: 10-01-2005, 06:43 AM
  3. Yet another newbie Mean Streak 2005 exhaust questions
    By uf-engineer in forum Kawasaki Cruisers
    Last Post: 09-27-2005, 01:30 PM
  4. Mean Streak Stock Exhaust - FREE!!!
    By brady666 in forum Accessory Swap Meet
    Last Post: 07-02-2005, 10:38 PM
  5. Mean Streak Exhaust
    By DrewBoy in forum Kawasaki Cruisers
    Last Post: 12-05-2004, 04:17 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
