I obtained my permit and decided to try riding. I bought all the gear etc etc.
Anyhow, I went out and tried on my friends Kawasaki Spectre 550. I had horrible luck. Kept dumping the bike, couldnt really get started on it, whenever I would get going it would wanna go to the left. Not quite sure what happened, but I will say its not the best starter bike. The handlebars are weird, they are bent inward more to your chest and I think that may have been messing me up. This Sunday im going to try and learn on a Honda Rebel 250. That should be a bit better. Anyhow, I have just a couple questions...mainly about turning/counter steering. When you are trying to turn the bike at low speeds, i know you dont countersteer, you just turn the direction you want to go (assuming I can start out on it and not dump it). How easy is it to muff up and dump the bike turning low speeds. My other concern is going around a corner/leaning. Do you have to forcefully lean, or does your body naturally lean with the bike. I know when you go around a corner you push right to go right, so basically your pushing in the opposite direction, ala counter steering. However, once the bike is into the corner, do you keep the handlebars pushed right and should that take you all the way around the corner? How do you get the bike upright again? Thanks for entertaining a potential new rider and answering my questions. Hopefully I can manage to get the Rebel upright without dumping it. |
Power Hungry V2K Rider
![]() Join Date: Apr 2005
First off, get into a MSF Begning Riders Course. They'll teach you the basics real fast. Takes an evening and a couple of days.
At low speeds (less than 15 MPH) just turn the handle bars. At higher speeds you don't really need to "push" on the handlebars. It's more like lean on the end of the bar and stay leaning/pushing on it until you are ready to point the bike in another direciton (like straight down the road). If you insist on teaching yourself, spend at least half an hour "duck walking" the bike across a parking lot. First with the engine off, then with the engine on and holding the clutch in. When you reach the other side, duck walk it bike around and point it in the other direciton. It sounds like you were tryng to put your feet on the pegs before you were moving. Some students unconciously lift their feet off the ground before the bike gets moving and the ballance is stable. DON'T TRY TO TURN UNTIL YOU CAN RIDE IN A STRAIGHT LINE. Ride across the parking lot and stop (with your feet [both of them] on the ground). Duckwalk the bike around and get pointed in the opposite direciton. Now, Ride straight across again. Repeat, repeat, repeat until you are boared to tears. The do it some more. Now you can start learning how to apply the brakes. BOTH of them at the same time. Once you got straight line riding down, start practicing turns at low speeds. ALL of this should be done in an empty parking lot that is at least the size of a basket ball court. Practice, practice, practice!
'00 Nomad '06 V2K LT Because RED is the fastest color... Last edited by BigJohn : 05-26-2006 at 03:47 PM. |
#4 (permalink) |
No, not quite ready to hop on and ride, thats the point of learning Sunday.
I think you are right, I do remember prematurely putting my feel on the pegs once or twice. This was done in a parking lot. Unfortunately, I signed up for the MSF course but they wont be able to get me into one until what looks to be late fall or next summer; bummer. So, I am going to practice, practice, and practice in the warehouse parking lot. Duck walking is a good idea. I will try that. But thanks so far. |
#5 (permalink) | |
#6 (permalink) |
Turtle Wax Taster
It sounds like you have the academics of turning down pat.
Yes, it is easy to dump the bike when doing low speed turns. It's basic physics. When you're at speed, there is more force pulling forward than down, centrifugal force I think, so you don't fall. At low speeds, the force of gravity exceeds the forward force of the bike, so you have to be more careful. It helps to shift your weight to the opposite side of your turn to balance the gravity. Also, accelerating through the turn will increase the gyroscopic effect and keep your bike upright. Don't just pull the clutch and coast through the turn. Slow down to a safe speed well before you turn, and then accelerate slightly through it while looking ahead through the turn. Your bike tends to go where you look. If you look straight down, that's where you'll end up. As far as forcing a lean when you turn, I'd say...sorta. You force the lean by just leaning your body and shifting your weight. You get back upright by doing just the opposite. Also, you do have to turn the wheel slightly when you turn, so getting back upright is just a matter of putting your wheel straight again and sitting up. The bike acts like a gyroscope...or one of those inflatable punching bags with the sand in the bottom. At speed, your bike WANTS to be upright and stable. If you stop leaning, it will pop back up for the most part. I believe it was once said that the most unstable part of a motorcycle is the rider. |
#8 (permalink) |
First, welcome to the forum.
as said, turning at low speeds is probably one of the easiest ways to muff up the bike early on. the bike is not helping you out at all to stay balanced. This is what I learned early on...when turning at low speeds the keys are to lean the bike slightly into the corner WHILE counter-weighting with your body to the outside...which means as you lean the bike over a little (not too much!), you use your body weight to the outside in order to keep everything balanced. As you do this, you also turn into the corner (yep, no counter-steering at slow speeds) If you try to lean the bike over into a slow corner, and don't counter balance with your body, you'll just tip over. Giving the bike a little lean will help you turn tighter. This may look and feel awkward at first, but it becomes natural after a while. After a while you’ll put more pressure on the pegs as you set this up, and kinda move the bike underneath you. Another piece that MUST be done in combination (and previously mentioned), is look where you want to go. If you're doing a left U-turn you want be looking roughly 90 degrees to the left, where you'll be exiting the turn, early on as you're entering the turn. I found that practicing looking further into the turn than I initially wanted to (because you feel like your not looking in front of you and will hit something) helped me out once I got used to it. In terms of leaning in higher-speed corners, I'd say that a few techniques compliment each other...leaning to a certain extent (not really “forcefully”), counter-steering, the amt. that you accelerate (yep, always want to accelerate through a corner, if even just barely - being off-throttle will make you somewhat unstable). It's not all leaning though, and it will kinda come naturally as you practice. I'd recommend taking the MSF - I took it a while after I learned, but it was still useful. well, hope that helps...good luck!
'05 ZX-6R Two Bros CF V.A.L.E. Zero Gravity Double Bubble Last edited by luvda6R : 05-26-2006 at 06:54 PM. |
#9 (permalink) |
MOM Sept 2006
Welcome to the forum. I read the first couple of lines and said to myself, "this guy needs to go to the MSF"...Get signed up for the MSF and don't thing about countersteering etc before you even know how to go a straight line...Be safe and smart.
Black 2006 ZX-10R
http://cache.www.gametracker.com/ser...0/b_560x95.png |
#12 (permalink) |
Banned
http://www.amazon.com/gp/product/188...lance&n=283155
and when you're done with that http://www.amazon.com/gp/product/193...lance&n=283155 |
#13 (permalink) |
TV Guru
Welcome to the forum. The others here seem to have you covered on the advice, so I can't really add anything except NEVER hit the front brake while turning or you'll fall in the direction you're turning. You can control low speed turns using the clutch and REAR brake, but keep yer paws off the front one. Good luck.
#14 (permalink) |
Heres an update for those who care:
I went out with the Rebel 250. What an easy bike to ride, and it was fun. I got all the techniques down mostly now. I spent about 3-4 hours doing basic stops and go's, cornering, etc, and hit the streets around evening. I had no problems at all, and never dumped the bike. Im pretty stoked. Time to get my own now. |
| *sigh* Yes more newbie questions | GCDisciple | Kawasaki Streetbikes/Sportbikes | 28 | 04-26-2006 11:05 PM |
| A few newbie questions | smcken2973 | Kawasaki Cruisers | 15 | 02-11-2006 12:05 PM |
| Newbie with questions | Mickey531M | Kawasaki Cruisers | 22 | 09-22-2005 12:02 AM |
| Newbie questions | 79batmobile | Kawasaki Streetbikes/Sportbikes | 6 | 08-03-2005 11:05 AM |
| newbie here, want a couple questions answered | slvr2000fdvspec | Kawasaki Streetbikes/Sportbikes | 10 | 11-29-2004 08:46 PM |
