Go Back   Kawasaki Motorcycle Forums > Welcome to Kawasaki Motorcycle Forums! > Main Lobby
Old 09-13-2006   #1 (permalink)
AMH
Default Removing rear tire on Vulcan 750!
Hello to all,
I needed to grease the shaft on my (04) 750 with 6k miles. Just wondering if I have to remove the right muffler or can I just take the shocks off and drop the frame low enough & take the axle bolt out?
Also, should I replace the O-ring? Kawasaki told me it shouldn't need replacing on 2004!
Thanks in advance for replies and happy riding!
AMH is offline   Reply With Quote
Old 09-13-2006   #2 (permalink)
Rick_in_P.A Wa.
Eliminating all others
Rick_in_P.A Wa.'s Avatar
I dropped the shocks seemed a better idea than risk damaging one of those pipe gaskets
*ZL900 *GSX750SE #197
I didn't change my mind.....I just added to my ORIGINAL PLAN
Rick_in_P.A Wa. is offline   Reply With Quote
Old 09-14-2006   #3 (permalink)
Rubline
Turtle Wax Taster
Rubline's Avatar
Just unbolt the bottom of the shocks and the swing arm with lower enough for the axle bolt to slide out. A little trick though, Before you put your bike on the center stand, but a peice of 2X6 under the stand before you raise it. It will raise the bike so you can remove the back tire more easily. As far as the O ring, inspect it,, the decide if you need to replace it. Prob not though.
Rubline is offline   Reply With Quote
Old 09-14-2006   #4 (permalink)
2WheelFun
2WheelFun's Avatar
Originally Posted by AMH
Hello to all,
Here's a great step by step with pics.
http://www.cdthayer.com/cruisermaint_2.htm
***KING KAHUNA***
***2007 V2K LT***
******PICS******
2007 Brute Force 650i
******PICS******
*I love the smell of SeaFoam in the morning*
2WheelFun is offline   Reply With Quote
Old 09-14-2006   #5 (permalink)
windrider18
Can't find time to ride
IIRC, the last time we did that on DH's 750, we didn't remove the mufflers, just the shocks. However, you may want to invest in a lift as it makes the job much easier (we have a Craftsman lift). The 750's frame will sit on the lift with no problems.
You also might want to recruit some help. A second person makes the job easier
Angela
'02 ZR-7S
Metallic Blue Violet
"Bluebird"
"I am not pretty baggage! I ride my own!"
windrider18 is offline   Reply With Quote
Old 09-14-2006   #6 (permalink)
GreenJello
Neuromancer Lvl 13
GreenJello's Avatar
750's got a center stand, so I'm guessing the lift isn't necessary.
The only valid censorship of ideas is the right of people not to listen. ~Tommy Smothers
GreenJello is offline   Reply With Quote
Old 09-14-2006   #7 (permalink)
windrider18
After having done it, the lift makes life easier...trust me.
Angela
'02 ZR-7S
"Bluebird"
Old 09-14-2006   #8 (permalink)
Rubline
Turtle Wax Taster
Rubline's Avatar
I removed the rear tire without removing the muffler. I had greased the splines on my 06. Good thing I did, the splines didnt have much grease at all. The entire job took me two hours from start to finish.
Old 09-15-2006   #9 (permalink)
2WheelFun
2WheelFun's Avatar
When we owned 2 750's I did the maintenance on both of them in short order. Here are some pics I took of that maintenance.
***KING KAHUNA***
***2007 V2K LT***
******PICS******
******PICS******
Old 09-15-2006   #10 (permalink)
2WheelFun
2WheelFun's Avatar
***KING KAHUNA***
***2007 V2K LT***
******PICS******
******PICS******
Old 09-15-2006   #11 (permalink)
2WheelFun
2WheelFun's Avatar
It's an easier job that you might think. The nice thing about using the harbor freight lift is that you can set your tools and parts on it as you continue to work while sitting in a chair...very comfy I might add!
P.S. The garage has been cleaned up.
***KING KAHUNA***
***2007 V2K LT***
******PICS******
******PICS******
Vulcan Classic 1500 bigger rear tire! Kenny Kawasaki Cruisers 14 07-23-2008 03:47 PM
***1600/1500 Classic/Nomad/Meanstreak/Maurader - Photo Contest*** Spok Kawasaki Cruisers 170 12-12-2006 06:12 PM
removing rear tire from ZX6R neek Kawasaki Streetbikes/Sportbikes 13 06-23-2006 01:24 PM
750 Vulcan rear end tear down & Motorcycle Lift 2WheelFun Kawasaki Cruisers 4 09-26-2005 10:04 AM
Left rear turn signal situation vulcan 750 kamafool The Mechanics Corner 2 08-23-2004 01:42 PM
