2006 Vulcan rear shocks question
+ Reply to Thread
Results 1 to 14 of 14
Thread: 2006 Vulcan rear shocks question
  1. #1
    Join Date
    Oct 2006
    Posts
    22
    Default 2006 Vulcan rear shocks question
    I want to add pressure to the shocks as I like running my bikes with stiff suspensions.
    I understand the bike needs to get the rear wheel off the ground to add air, but how do people do this without some special equipment? Is there some secret to getting the read wheel airborn?
    I tried adding air to the left rear shock tonight with the bike on the ground and it would lose the pressure to near zero the minute I took the nozzle away every time.
    I think thats because the bikes weight is pressuring the shock and it is stressed so loses the air quickly? I did manage to get it to hold 20psi for now but I think I want to run these at 55, understanding from the manual that 73 psi is topped out.
    What do I need to be able to do this without going to the dealer, and how to hell would you do this on the road on a trip?
    Thanks in advance
    Brownie
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #2
    Neuromancer Lvl 13 BTK Expert GreenJello's Avatar
    Join Date
    Jul 2006
    Location
    Cincinnati, Ohio
    Posts
    519
    Which Vulcan do you own? I've got a 750, it's got a center stand that makes this easy.
    The only valid censorship of ideas is the right of people not to listen. ~Tommy Smothers
  4. #3
    Join Date
    Oct 2006
    Posts
    22
    Nomad 2006
  5. #4
    Forum Supporter Forum Supporter Plato's Avatar
    Join Date
    May 2004
    Location
    East Texas
    Posts
    2,603
    Scan this thread: http://www.kawasakimotorcycle.org/fo...light=pressure
    You can get the rear off the ground with an automotive jack, but you had better be sure to tie off the handle bars and really have the front end secure. Much better to get a motorcycle jack or a lift of some kind.
    However, I followed NY_Guy's advise in the link above and put the air in with the rear on the ground. DO NOT use a standard air pump as you can easily blow the seals on those shocks -you need one of the progressive air pumps that allow very fine measurements and don't allow the air to be lost when connecting or disconnecting the pump.
    Hope that helps...
    05 Nomad/V&H Baggers/PCIII/Caddman
    Risers/Lights/Lowers/Chaps
    www.home.earthlink.net/~mthompson61
  6. #5
    Join Date
    May 2004
    Location
    East Texas
    Posts
    2,603
    Quote Originally Posted by brownie
    ...I tried adding air to the left rear shock tonight with the bike on the ground and it would lose the pressure to near zero the minute I took the nozzle away every time...
    Here's what you need: http://www.cruisercustomizing.com/de...ini_Gauge_Pump
  7. #6
    Join Date
    Oct 2006
    Posts
    22
    I bought a bike pump that works fine for getting the air in, but I can not seem to get the valve off fast enough and the shock keeps losing it's pressure immediately.
    If I buy that progressive guage/pump, is that going to be the same issue I'm having presently? The pump I'm using has that locking lever and by the time I pull it off, the air is out of the shock.
    I thought it was because I had weight on them with the rear not off the ground. Is this thinking on the right track or not?
    I bookmarked the jack stand, I may buy one of those.
    Brownie
  8. #7
    Join Date
    May 2004
    Location
    East Texas
    Posts
    2,603
    If I buy that progressive guage/pump, is that going to be the same issue I'm having presently? The pump I'm using has that locking lever and by the time I pull it off, the air is put of the shock....
    No, the progressive pump you see in that link above -has a valve that prevents the air loss while connecting and disconnecting. It is specifically designed to perform this task for shocks. I think they have a selection to choose from based on the max pressure limit you want (15psi, 30psi, 60psi, etc). And they're small enough to carry in a saddlebag, get the 60psi unit and you could even use it to air a tire in an emergency -although the design is such that you would have to do A LOT of pumping on a Nomad tire
  9. #8
    Join Date
    Oct 2006
    Posts
    22
    Plato,
    Thats just what I'm looking for. I'll order one on Monday asap.
    This place is going to be a wealth of knowledge and make owning the nomad that much more enjoyable.
    Thanks again
    Brownie
  10. #9
    Join Date
    May 2004
    Location
    East Texas
    Posts
    2,603
    ...This place is going to be a wealth of knowledge and make owning the nomad that much more enjoyable...
    This forum is great for quick feedback for sure
    However, you should bookmark gadget's webpage for sure -it'll give you hours of reading and great info for the Nomad: http://www.gadgetjq.com/gadgetsfixitpage.htm
  11. #10
    Join Date
    Oct 2006
    Posts
    22
    Bookmarked it as suggested.
    I'll be reading this afternoon after the honey do list has been knocked down a peg or three
    Brownie
  12. #11
    Foil Inspector BTK Beginner
    Join Date
    Oct 2004
    Location
    Central Virginia
    Posts
    107
    Wink
    DO NOT spend a fortune on a Progressive Air Pump! You can go to any bicycle shop, and buy a Fox Shox No Loss Air Pump for about $30. If you plan on putting 55-psi of air in your shocks, you better tie yourself to the seat. You'll probably bounce off the seat after driving over the first bump. Unless you are over 350-pounds, I'm sure you can get by with 25-35 psi. I have added air with the wheel on the ground and off the ground, there isn't any difference. Just make sure you add/adjust when the bike is cold. Riding around will heat up the air in your shock, so your reading will be off. I'd start with 25-psi and work my way up 5-psi after a good day of riding. This way you'll have a chance to really decide what works better for you. I've got a Nomad, and two up with luggage, I'm running 35-psi. I'm a big boy of 225 and the wife is well, I better not say.
    "No man is above the law and no man below it; nor do we ask any man's permission when we ask him to obey it." ...Theodore Roosevelt
  13. #12
    Living on the dark side Forum Supporter Xlr8n's Avatar
    Join Date
    Aug 2005
    Location
    midwest
    Posts
    2,541
    +1^^^ Get a bicycle suspension no-loss pump. 25-30 bucks.
    '03 1200 Sporty
  14. #13
    Wants better weather! BTK Expert mrider's Avatar
    Join Date
    Aug 2005
    Location
    batesville,arkansas
    Posts
    839
    Harley dealers has them for 20 or so dollars. Just tell them you have a 2007 Screaming Eagle Ultra Glide
    keith
    2004 kaw. nomad
  15. #14
    Join Date
    Oct 2006
    Posts
    22
    too late, I ordered the progressive yesterday. If it is not to my liking, I'll send it back, otherwise, I bit the bullet on this one, but thanks to all for the great suggestions.
    Brownie
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. 2006 Kawasaki Vulcan 500 LTD
    By Caric in forum Streetbikes Buy/Sell/Trade
    Last Post: 03-24-2007, 11:59 PM
  2. Replies: 170
    Last Post: 12-12-2006, 05:12 PM
  3. Vulcan 900 rear brake
    By cow900 in forum Kawasaki Cruisers
    Last Post: 09-25-2006, 12:18 PM
  4. Lower rear 2003 vulcan 1600
    By imbikes in forum Kawasaki Cruisers
    Last Post: 10-20-2004, 10:54 AM
  5. 94 Vulcan 500 speedo cable routing question
    By mikeyc222 in forum The Mechanics Corner
    Last Post: 09-04-2004, 11:41 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
