Go Back   Kawasaki Motorcycle Forums > Welcome to Kawasaki Motorcycle Forums! > Main Lobby
Old 04-10-2007   #1 (permalink)
newbCalChr
Foil Inspector
Default do you know why i stoped you?
the other evening i was out driving and i was passed by this sport bike that had the most brightest head lights well i turned my car around in the center of the road and started flying after him well i flashed my lights turned on my hazards and followed him well he pulled over and i got out and walked up to him and asked what kind of headlights he had he said they were piaa bulbs and drving lights or something like that so my question is this can i get that for my ninja ex250 and if there is anything better?
Caleb C
newbCalChr is offline   Reply With Quote
Old 04-10-2007   #2 (permalink)
Tod
I yam what I yam
Tod's Avatar
I think someone over on the 250 riderforum found both a sylvania silverstar and a piaa H2 that would work, but he had to beef up the relay or something to make it work.
“Saying what we think gives us a wider conversational range than saying what we know.” - Cullen Hightower
Tod is online now   Reply With Quote
Old 04-10-2007   #3 (permalink)
newbCalChr
Foil Inspector
thanks
Caleb C
Old 04-10-2007   #4 (permalink)
xeon
Wants better weather!
xeon's Avatar
All you have to do is buy and install a 9003/H4 PIAA or SilverStar lamp. SilverStars are much cheaper than the PIAA and IMO give off almost the same light. PIAAs seem to not last as long as SilverStars and neither seem to last as long as regular halogens. I think the PIAAs overdrive themselves somehow, but I have never dug into it, but that would explain their shorter life. IME, overdriving a lamp is a function of the system not the lamp though... in short I'm not sure.
http://www.piaa.com/Bulbs/Bulbs-H4.html
http://www.sylvania.com/ConsumerProd...r/ProductLine/
The SilverStars are available in single packs for motorcycles. My Wal-Mart carries them.
Black '06 Ninja 250R
Red-n-Silver '99 YZF600R
xeon is offline   Reply With Quote
Old 04-10-2007   #5 (permalink)
Tod
I yam what I yam
Tod's Avatar
I think the reason the guy upgraded his relay was to help with the bulb life.
Somethig about the stock relay didn't give the higher wattage bulb the right kick to start it off, making the bulb work harder at startup, which shortens the life.
Old 04-10-2007   #6 (permalink)
Sassy Chassis
Much love to my Kawi Pals
Sassy Chassis's Avatar
Send a message via Yahoo to Sassy Chassis
I had the SilverStar for the Ninja...was definitely very bright and noticeable.
2002 Ninja 250
SOLD!!!!
2004 GSXR 600 Yellow & Black, Yeah Baby!!
Sassy Chassis is offline   Reply With Quote
Old 04-16-2007   #7 (permalink)
CatchMeIfYouCan
Downunder Newbie
CatchMeIfYouCan's Avatar
Default Relays and brighter bulbs
Hi Tod..
Tod here..
The reason for adding relays is when you go to brighter bulbs, even if it is a simple switch to more wattage (without the new high tech ones, which give off better, brighter light at same wattage), you run the risk of doing expensive damage.
Years ago, I used to run twin 90/130 bulbs in the GSXR750G, in 1985. The upside was fantastic lights at night, the downside was the heat generated meant highway riding was fine. Sitting around in traffic without the additional cooling of the airflow meant regular burnt out bulbs.
If you are making a LARGE jump in wattage, ensure your source can cope with it (the alternator). You need to ensure it runs ALL your lighting, with spare to run the rest of the smaller things on the bike.
Then, relays will be needed as the actual headlight switch will burn out if you are drawing lots more power due to the lights. This can become expensive to replace regularly
So once you know you have the juice and you've had the relays wired in, fit the bulbs of choice in and enjoy the enhanced safety of better lighting!
Cheers all from Downunder. Tod.
When I was young, I used to race - now I try to ride at a more leisurely pace.
CatchMeIfYouCan is offline   Reply With Quote
Old 04-16-2007   #8 (permalink)
Idaho
Forensic Bug Splatter Analyst
Idaho's Avatar
I run a PIAA bulb and of course it is much brighter, sort of a blue/purple light. But the current load pulls the same amount as a stock bulb. I've been very happy with it.
2004 Blue Marauder 1600
http://www.CruiserCustomizing.com/Idaho
Idaho is offline   Reply With Quote
Old 04-16-2007   #9 (permalink)
Tod
I yam what I yam
Tod's Avatar
Yeah, that's what it was, his switch kept burning out, so he put in a different relay and a new switch and all was fine after that.
Old 04-16-2007   #10 (permalink)
zedx11
Banned
if they are putting out that much heat when in traffic wouldn't it melt warp the headlight housing?
zedx11 is offline   Reply With Quote
Old 04-17-2007   #11 (permalink)
CatchMeIfYouCan
Downunder Newbie
Default Enough heat to overheat the filament
Enough heat to overheat the filament - which causes the bulb to go.. Not enough to melt a housing (as the heat is reflected), as designed.
When in traffic, the heat isn't dissipated, thus, the bulb goes.
Cheers, Tod. Aussie.
PS - The increase in wattage is not needed so much nowadays, with the new generation of bulbs.. See the links a few posts up.
Old 04-17-2007   #12 (permalink)
Tiger77
Tiger77's Avatar
sheesh - I'm just surprised that you managed to catch a sport bike in a cage. I didn't know that was possible.
Tiger77 is offline   Reply With Quote
Old 04-17-2007   #13 (permalink)
Tweek
Propensity for velocity
Tweek's Avatar
Send a message via MSN to Tweek
He was in the millenium falcon. it will do the Kessel run 3 parsecs.
I am part of a redneck agenda
Tweek is offline   Reply With Quote
Old 04-17-2007   #14 (permalink)
MR.S7
Way Too Much Free Time
MR.S7's Avatar
Send a message via ICQ to MR.S7 Send a message via Yahoo to MR.S7
PIAA are the best. i have them on my car..
MR.S7 is offline   Reply With Quote
Old 04-17-2007   #15 (permalink)
Pistobah
Workin too much
Pistobah's Avatar
I had 2 PIAA's on my ninja, but one burned out, so i've got one stocker(brights) and one PIAA(low beam).
Chris
'08 GSX-R750
'05 ZX-6R
'05 SV650S
1954 BMW R51/3
Pistobah is offline   Reply With Quote
just stoped in...nubie rxraptor02 Main Lobby 22 11-21-2005 09:23 PM
