Go Back   Kawasaki Motorcycle Forums > Welcome to Kawasaki Motorcycle Forums! > Main Lobby
Old 06-07-2007   #1 (permalink)
taro
Wants better weather!
Smile I'm so embarassed...Am I doing it too much?
Stoopid question. With the lack of rain we've been having lately, I've been getting a lot of mileage in for the last two weeks. I feel like an old man complaining about this, but...my left ankle is getting to the point where it's beginning to protest when I upshift. I don't know if this is from shifting so much or if it is because I keep trying to shift into 7th gear like an idiot. Any thoughts?
Also, I've been getting some pain on the outside of my right knee. I have an ex500 and I'm hanging off the bike pretty often (although I've yet to drag a knee). Thanks.
taro is offline   Reply With Quote
Old 06-08-2007   #2 (permalink)
StarGate
Navy Vet S.A.R. crew
StarGate's Avatar
I remember one bike I had many years ago that gave me a problem shifting. I was having to strain to pull up enough to shift. I ended up taking the shift leaver off and repositioning it a little lower. Never had another problem shifting.
I've already had surgery to fix both knees so I won't go there.
Mike
Original Owner
1981 KZ1000-K1 LTD
2000 Suzuki King Quad
Photos
Old 06-08-2007   #3 (permalink)
eidian
Black is faster, right?
eidian's Avatar
I asked members in a 500 forum if I was the only one who consistently tried to shift to "the elusive 7th gear". I was not, much to my relief, so don't feel embarrassed.
I started it doing after I began to use the freeway to commute; my wife and I moved into our condo a few months ago and I started to take the HOV Lane. I'm the master at shifting in LA traffic on the streets but I'm still getting used to the faster speeds (gear-wise) on the freeway. How about you Taro...do you try to shift into 7th on the freeway only or is it all of the time?
'07 black Z1000: Power Bronze/Projekt D/EYI Designs/Leo Vince/Puig/Galfer/T1Concepts
eidian is offline   Reply With Quote
Old 06-08-2007   #4 (permalink)
MauiAl
Evil Doer
MauiAl's Avatar
To directly answer your question the only person I knew that did it too much was wife number one. She was doing it, oh I don't know, maybe 10 times as much as I was.
Have a tach? Easy to check rpm against speed if you're already in 6th.
Just More Whining
MauiAl is offline   Reply With Quote
Old 06-08-2007   #5 (permalink)
taro
Mike, thanks for the tip. I'll look at what adjustments I might be able to make to the lever.
Eidian, I try to cruise in 6th to try to save on fuel when I'm comfortably tailing someone who is going faster than I'd normally cruise. But growing up on small four cylinder cars, I'm very quick to downshift when I feel the need to have the ability to get out of trouble or if I'm taking some curves. What I end up doing is downshifting to fourth or third, pretty often and then once I make a pass, am away from "trouble," or end up on a long straight, I then try to upshift quickly back up to 6th. I'm thinking that once I get up to third or fourth depending on what kind of road I'm on, I'm no longer winding out each gear and so I just short shift to 6th. Because I'm not consistent with being aware of what gear I'm in, I end up going for 7th.
Al, I think you're right. I'll have to get more consistent with my gear awareness so my body will stop making me feel older than I think I should feel.
Old 06-08-2007   #6 (permalink)
Thmastr
rain is here
Thmastr's Avatar
if I remember correctly 6th @ 65 gave me about 6k rpm.. or 6.5k rpm.. It just takes a little getting used to.
out in the twisties I won't even look at my spedo, but my tack, that tells me what gear I am in.. if it seems fast and im about 11k rpm ill be in 2nd, same speed but lower rpm means im in 3rd...
Proud owner of an 06 Ninja 250.
Yes I am 6'4 and yes I weight 160 lbs
Thmastr is offline   Reply With Quote
Old 06-08-2007   #7 (permalink)
Christo
Christo's Avatar
I have to say, I was thinking you were on a bout something else from the title! Hope the hair recedes and the vision improves!
"There's a difference between knowing your path...........
............and walking it!"
Christo is offline   Reply With Quote
Old 06-08-2007   #8 (permalink)
A2rider
Banned
A2rider's Avatar
Don't feel bad, I'm looking for 6th on my bike all the time. Maybe one day I'll figure out it doesn't exist.
A2rider is offline   Reply With Quote
Old 06-08-2007   #9 (permalink)
stefano
Needs A Real Job
stefano's Avatar
Glad to know I'm not the only one who gets that pain in the right knee - I can't figure out why it's only the right one... but know you're not alone.
I used to try and shift into 7th all the time when I was new on the bike... nowadays it happens less often but... it still happens
As for the ankle, wouldn't be able to say if it's you or the bike...
06 636 - the last of it's kind
stefano is offline   Reply With Quote
Old 06-08-2007   #10 (permalink)
fretbuzz
Non Omnis Moriar
fretbuzz's Avatar
Bwaaaaaahahahahah
fretbuzz is offline   Reply With Quote
Old 06-08-2007   #11 (permalink)
stefano
Needs A Real Job
stefano's Avatar
Originally Posted by nomad16 View Post
Bwaaaaaahahahahah
LMFAO you twisted, son!
Old 06-08-2007   #12 (permalink)
taro
Thanks for the feedback. I'm gonna try to be better about knowing what gear I'm in. Don't know what to do about the knee yet.
Old 06-08-2007   #13 (permalink)
vulcan500rider
2006 Suzuki C90
vulcan500rider's Avatar
How about adding a heel/toe shifter. I have one on my c90 and don't have to use my toe (or ankle) at all.
2006 Suzuki C90
vulcan500rider is offline   Reply With Quote
Old 06-08-2007   #14 (permalink)
taro
Never even heard of that. Thanks for the tip. I'll look into it.
Old 06-08-2007   #15 (permalink)
hayward6
Former Marine
hayward6's Avatar
I think there must be something wrong with me, like a "tic" or something because I find myself constantly counting the gears as I shift up and down... It would be impossible for me to not know what gear im in because this counting kinda happens subconsciously.
1984 ZN1100 LTD -SOLD-
1975 Suzuki T500 Titan -Project-
hayward6 is offline   Reply With Quote
A little embarassed to ask Idaho Kawasaki Cruisers 24 05-03-2006 10:44 AM
