Sit speling cheker
I have the fleeced lined ICON Barrier pants and they're great for those cold mornings, very warm, I love them!
But my pants stink!! I have seen them at two different ICON dealers and they all stink!! Does anyone have the same problem? If so why do they stink? |
RIP Deron Harden :-(
sorry i can't help, just don't like seeing a post go unanswered. good luck with that ! must be something in the material if the others you've seen have the same problem.
David - Moderator 2002 Suzuki DRZ400 2003 1500 Meanie, scraping pipes and frame :-) In loving memory of Deron Harden, forever in our thoughts :-( |
#6 (permalink) |
Finally Got Into First Gear
At the risk of showing my domesticated side, try washing again an then in the last 'rinse' use a minimum of water, just enought to make it sodden, then add two or three caps full of vanilla essence, work it through or even let it soak for some time, then hang to dry from wet (don't wring it out).
I do not know those pants, or the smell but this is a trick I use for various 'smells' (even used it sucessfully when my cat p!$$ed on the car seat...) You might of course smell like an ice-cream factory instead!
Time flies like an arrow. Fruit flies like a banana. |
#7 (permalink) |
well, as long as you like vanilla, that doesn't sound like too bad of an idea to me ! and if vanilla isn't your thing, try a different scent.
