Go Back   Kawasaki Motorcycle Forums > Welcome to Kawasaki Motorcycle Forums! > Main Lobby
Old 05-12-2008   #1 (permalink)
zippy527
Default Help Me Please
i have a 89 ninja 600c, i cleaned the tank petcock, replaced batery plugs cleaned the carbs, it still runs like shyt i give it full throttle it it will bog down llike it wants to die if i hold it it will eventually run right any ideas?
zippy527 is offline   Reply With Quote
Old 05-13-2008   #2 (permalink)
CTRider
TV Guru
CTRider's Avatar
When was the last time it was run? You may have a clogged fuel line, a stuck float, dirty float needle or a mouse nest in your exhaust.
Did you check the airbox for a dirty filter?
Is it just bogging or is it backfiring too?
1983 Honda CB550
About Me
Answers to your Gadget Questions
Gadget Forum
CTRider is offline   Reply With Quote
Old 05-13-2008   #3 (permalink)
antiq
Needs A Real Job
antiq's Avatar
Air filter plugged and carb problems come to mind.
Patience and persistance- pays
82 KZ750LTD
78 KZ750 twin
Vince
antiq is offline   Reply With Quote
Old 05-13-2008   #4 (permalink)
2WheelFun
the "fun old" guy
2WheelFun's Avatar
Did you clean the carbs "inside and out"? And when you say you cleaned the carbs...how did you clean them?
Since it's running it might be worth it to add SeaFoam to the gas and go for a ride (on a non busy street/road) and see if that helps clean the carbs/gunk more. Sometimes it can help but if the carbs are really dirty/plugged you may need to remove them and tear them do and do a "deep cleaning" and possibly rebuild them.
***KING KAHUNA***
***2007 V2K LT***
******PICS******
2007 Brute Force 650i
******PICS******
*I love the smell of SeaFoam in the morning*
2WheelFun is offline   Reply With Quote
Old 05-13-2008   #5 (permalink)
Connman
03 ZX-12R
Connman's Avatar
check fuel filter screen?
Any 12 people who can't get themselves out of jury duty are not my peers.
Connman is offline   Reply With Quote
Old 05-13-2008   #6 (permalink)
zippy527
i took off the bowls sprayed the jets it does backfire idk whats wrongwith it it not the air filter ive put a new one in cleaned the whole airbox, anyideas?
Old 05-13-2008   #7 (permalink)
zippy527
yea it backfires too, i took the carbs off undid the bowls sprayed carb cleaner through them, sprayed the jets, there was like a red powder at the bottom of the bowls though
Old 05-13-2008   #8 (permalink)
antiq
Needs A Real Job
antiq's Avatar
Sounds like your fuel tank has a bit of rust. Put on an inline filter and try running it with some Seafoam. If that doesn't fix it it will probably need a thorough carb cleaning.
82 KZ750LTD
78 KZ750 twin
Vince
Old 05-13-2008   #9 (permalink)
antiq
Needs A Real Job
antiq's Avatar
Have you checked your valves? If they are out of adjustment you'll get these same issues.
82 KZ750LTD
78 KZ750 twin
Vince
Old 05-17-2008   #10 (permalink)
zippy527
hey i used that sea foam it cleaned my motor, i used hydrochloric acid cleaned my tank it still did it i took off the carbs the air fuel screw was completely shut thanks for the help guys
Old 05-17-2008   #11 (permalink)
zippy527
how importan is the fuel evaporator system?
