LinkBack | Thread Tools |
Bridal Boutique Manager
So I thought to myself this morning...I think I'll go change the oil, haven't done it since I bought the bike, its probably about time.
Shouldn't be a problem, I've done thousands of oil changes in my day, what's one more? First surprise comes before I even start. Walk in to buy the stuff...they charge me 12 bucks for the oil filter! Wth? For 12 bucks it better wipe my butt too! But then again this is the same place that tried to rip me off on a tire so I probably shouldn't be too surprised. Ok, so 12 bucks is 12 bucks, another 23.97 for a gallon of oil and I head home. I pop open my manual, its got a little picture with a nice arrow pointing to the drain plug. Ok, I can see that myself, but where's that 12 dollar filter? "If the filter is to be removed during the service please visit an authorized Kawasaki dealer". Yeah screw that. Remove the lower right fairing, pretty straight forward process, except I though one part snapped off but there were two more screws, good thing I found them before I started pulling. And lo and behold, there it is. Way in there in the birds nest of header pipe, that little black 12 dollar filter. Ok, time to drain the oil. Crack the plug loose, screw it about halfway out, and here comes surprise number 2. That nice aftermarket exhaust passes underneath the drain plug, and its actually so close that theres not enough room to take out the plug. Ok, time to get some pliers, take off that little spring holding the two parts of the exhaust together, push down a little and out it comes, followed shortly by a rush of hot dirty black oil. Now my new problem is the drain pan I have is too tall to fit under the bike so I shove it under there and "most" of the oil makes it inside. Oh and I notice there's a drain plug gasket I didn't know about, so of course I didn't have a replacement, but its a metal one so screw it, I put it back in. I didn't change the gasket on my car for 2 and half years and it didn't leak, lets hope my luck keeps up. Now back to my best friend the 12 dollar filter, and with him surprise number 3. My strap wrench doesn't fit on it, the filter is too small. Crap. I could stab it with a screwdriver and twist it off that way, but thats gonna make a pretty big mess, and I usually try to avoid that. So I head over to the Yaslinskiys house to borrow some filter pliers. Can't get the garage open because Yaro's truck is to close and the door garage door hits the bumper when we lift up on it. Orest goes inside to get the the keys, turns out Yaro took them with him. So we grab a piece of wood, break into Yaro's truck, roll it back a little and open the garage. After searching through a pile of tools a tornado could have put there, we find the filter pliers. Sweet, I'm almost done. Except I get another surprise. The pliers are broken, and wont stay locked on the setting I need. By this time I'm slightly ticked off so I take a screwdriver and stab the filter anyways. The pan isn't even close to being short enough to fit under where the filter is, so the contents spill out onto the floor. I took a brand new roll of paper towels and used up about half of it cleaning up the mess. I was gonna funnel the oil into the pan, but that plan died when I had to impale the filter with a screwdriver to get it off. Ok, finally, almost done! Fill it with oil, fire it up, nothings leaking, nothing clanging around, no oil spewing from the filter, cool. Go to put the plastic back on and it decides to give me some trouble, stupid bracket wouldn't snap on and I ended up with an extra screw somehow, but oh well, hope it holds and doesn't fall off on the freeway like Brian's did. So I'm done, a 30 minute job took me about 2 hours, and now the stupid tool kit somehow grew in size and doesn't fit under my seat anymore...how that happened I don't know |
#6 (permalink) |
Novice Tank Roller
![]() Join Date: Oct 2007
you forgot the beer. that was your problem!
NCDave Our Lady of Blessed Acceleration, don't fail us now. - Elwood Blues http://www.bikepics.com/members/ncdave/ |
#8 (permalink) |
TV Guru
![]() Join Date: Apr 2005
Sounds about like changing the oil on the original Concours.
That was yet another part of the curb appeal of my bike: Plenty of room underneath for an oil pan and the oil filter is right up front between two of the exhaust pipes (with plenty of clearance on either side). The only downside is it uses the bolt-on style oil filters. That means more mess and a little more cost for the filter. The nearby Honda shop charges $7.50 for them, which isn't bad considering no modern bikes use them. |
#9 (permalink) |
SKOL VIKINGS!!!
No beer? No wonder. So you broke in to a friends truck using a piece of wood? Holy crap...if you lived next to me, I'd just give you a key the garage so you don't need to ruin my cages!
Adam L Stensby Doubt is the seed of all knowing Adam's Mean Streak Crysti's 900 Classic |
#13 (permalink) | |
#14 (permalink) | |
TV Guru
Note to self: don't leave the keys in a vehicle that automatically locks its own doors and rolls up its windows when you turn off the engine and exit it. |
#15 (permalink) |
Yeah I locked my keys in the trunk of my old honda prelude that I had. I called my dad and told him to bring the spare key and he says he's never heard of a spare key (I gave it to him)
So we tried to slim jim it open for about 3 hours, used a coathanger and everything we could think of, the neighbor brought over a real slim jim, and nothing worked. Then my dad calls me and says he found the spare key. We were camping last summer and my friends little brother locked the keys in their van and AAA came out, they pretty much wedged this woopie cushion type aparatus under the door, pumped it full of air to wedge it open and then reached in with something and unlocked the door. |
#17 (permalink) |
I was at D.O.D #1!
My first oil change went fairly smoothly...until after I dumped out the used oil and found that gasket at the bottom of the pan. Too late to put it back on since the new oil was already in, so it will have to wait till next time.
1998 Vulcan 800 classic "Grit, spit, and a whole lot of duct tape!" My motorcycle pics! |
#19 (permalink) |
Guilty By Association
i put my bike on 2 2x6 boards under each tire and used 4 old college textbooks under the kickstand...worked pretty good. *if you do this and drop your bike off it, I am not responsible* lol
2008 vn900custom Those who dance are considered insane by those who don't hear the music |
#20 (permalink) | |
Turtle Wax Taster
2004 Suzuki Marauder |
| first oil change..... sheesh | Natsack | Kawasaki Streetbikes/Sportbikes | 34 | 03-30-2009 09:19 PM |
| in the mail - Vulcan 2000 Oil Level Check Procedure | Spok | Kawasaki Cruisers | 22 | 11-05-2008 12:19 PM |
| Oil Change Instructions | BigJohn | Off Topic | 20 | 03-24-2008 12:56 PM |
| oil change, Now oil Light on, HELP! | DaveinNM | The Mechanics Corner | 5 | 09-04-2004 11:55 PM |
