Go Back   Kawasaki Motorcycle Forums > Welcome to Kawasaki Motorcycle Forums! > Main Lobby
Old 07-04-2008   #1 (permalink)
jap thrasher
Post valve adjustment, more or less clearence as they wear.
Having read so many different reasons why valve wear increases or decreases valve clearance. I was surprised that no one explained the reason why.
There are three different ways to operate the valve train in an engine.
The most common type for years was the pushrod type found in most forms of high performance car engines. When flathead -- flathead came from the look the engine had, (L head combustion chamber.)-- type engines in cars went bye bye after WWII, because the valves were located in the block wtih the pistons and cylinders, the valve sank into the block and not the head therefore decreasing valve clearance. In the pushrod engine (known as the overhead valve type), because the valve train and rocker arms that pivot when the pushrod pushes up from camshaft to open valves, the camshaft was still below the valves. Since the valves were in the head and not in the block like the flathead. The overhead valve train wears differently because of the pivot wear. so valve clearances increase.
Most of our real perfomence bikes are called overhead camshaft (meaning the cam runs over the top of the valves and in most cases in direct contact with the camshaft thus eliminating the overhead valve train parts) because the valve will always wear into the seat and head direction thereby decreasing clearance.
Adjustment of valves becomes critical as the ratio of horsepower to cc increases and the rpm's go up as they do today.
--jap thrasher
jap thrasher is offline   Reply With Quote
Old 07-04-2008   #2 (permalink)
antiq
Needs A Real Job
antiq's Avatar
That's clear as mud to me and I suspect in error on some points.
Patience and persistance- pays
82 KZ750LTD
78 KZ750 twin
Vince
antiq is online now   Reply With Quote
Old 07-04-2008   #3 (permalink)
B.O.A.T.
Loud Pipes Save Lives!
B.O.A.T.'s Avatar
Talking
Ha, Ha, Ha,!!! That one really mad me laugh, I'll have to use that the next time that my wife tries to explain something to me.
VULCAN 800A
B.O.A.T. is offline   Reply With Quote
Old 07-04-2008   #4 (permalink)
elr658
Motorcycling's Dr. House
elr658's Avatar
It doesn't matter where the valves are located or what they are actuated by. Valve lash will always DECREASE as the valve seat will POUND into the substrate material. This has been the case in the THOUSANDS of motors I have done valve lash adjustments to. In the case of a rocker arm style of motor, if it loosens, YOU DIDN'T DO IT CORRECTLY.
1982 Kawasaki KZ1000R1 #658
1979 Honda CB750/1123FZ
www.myspace.com/79cb750f
ex 500 valve adjustment zverka1 Projects and "How To" Write Ups 3 09-27-2007 09:17 AM
bayou 250 valve clearence bayou Kawasaki ATV and Mule 0 06-18-2007 11:16 AM
Mule 610 1st valve adjustment interval? wrag Kawasaki ATV and Mule 1 06-20-2006 05:11 PM
89 zx600R Valve Adjustment Superfly The Mechanics Corner 4 05-01-2006 02:51 PM
valve adjustment question chesthing Kawasaki Streetbikes/Sportbikes 2 12-12-2005 09:12 PM
