Go Back   Kawasaki Motorcycle Forums > Welcome to Kawasaki Motorcycle Forums! > Main Lobby
Old 11-19-2003   #1 (permalink)
CHAPMANBATMAN
Default MY 2003 KX250 BAD SHAKE FRONT FORK,
DOES ANY BODY ELSE HAVE A PROBLEM WITH THE FRONT FORKS GOING INTO A BAD SHIMMY AT HIGH SPEED?
CHAPMANBATMAN is offline   Reply With Quote
Old 11-19-2003   #2 (permalink)
bikeaholic
Sick & Twisted Moderator
bikeaholic's Avatar
Send a message via AIM to bikeaholic Send a message via Yahoo to bikeaholic
Default re
never had that happen-might want to check the front wheel for loose laces or have the wheel balanced
2004 - 1600 classic
1997 - 1200C harley sporty
1985 - 750 Honda Shadow
VROC# 20171
Chromaholic #512
bikeaholic is offline   Reply With Quote
Old 11-19-2003   #3 (permalink)
CHAPMANBATMAN
Default FRONT SHAKE, POSSIBLY TIRE NEEDS TO BE BALANCED
THANKS, NEVER KNEW YOU COULD BALANCE THEM, OR EVEN THOUGHT ABOUT THAT, WHERE CAN YOU GET THAT DONE, IF YOU WOULDNT MIND ANSWERING THAT. EITHER HERE OR CHAPMANBATMAN@hotmail.com. thanks,
Old 11-20-2003   #4 (permalink)
bikeaholic
bikeaholic's Avatar
Default re
most any quality shop should be able to check the wheel for trueness - they have little weights that can be put on the laces to balance the wheel ,but if the laces are loose they can be fixed-if the rim is bent for some reason the its replacement time just find the best shop in your area and have it checked-and don't ride it till then - a bad front wheel is not too cool!
2004 - 1600 classic
VROC# 20171
Chromaholic #512
Front fork seals dgenx66 The Mechanics Corner 3 02-07-2006 04:17 PM
Modified 2003 or 2004/5/6 KX250 ckevg Kawasaki Motocross and Offroad 3 01-05-2006 01:09 AM
1989 KX250 Front Shocks magicmike Kawasaki Motocross and Offroad 1 12-08-2004 09:21 PM
Front Fork Problem VN1500??? grunt The Mechanics Corner 3 09-16-2004 06:30 PM
in search of front fork tubes vn750 tr0ll2 Accessory Swap Meet 1 02-01-2004 12:33 AM
