Go Back   Kawasaki Motorcycle Forums > Welcome to Kawasaki Motorcycle Forums! > Main Lobby
Old 11-11-2008   #1 (permalink)
bernsax
Saxman
bernsax's Avatar
Default Kawasaki Paint
I found an individual who is selling a trunk that will attach to my 2004 Nomad.
However, it is the wrong color. I was informed by a local Kawasaki dealer that Kawasaki does not sell paint and I should go through Colorrite.com.
I went to that site and the cost is $82.00 per cup. WOW!!!!! Since I need both blue and silver that amounts to $164 just in paint cost for that trunk!!!!!!
I thought I would go through an auto parts dealer to purchase it cheaper but the color code colorrite.com provides doesn't match up with their charts.
Does anyone know where to find the color code? It is not listed in my manual, at least I can't find it.
I'm temped just to buy the trunk and have an auto body shop attemp to match it as close as they can.
Does anyone have any suggestions?
I would appreciate any insight.
Thanks
04 Nomad
bernsax is offline   Reply With Quote
Old 11-11-2008   #2 (permalink)
RichLockyer
RichLockyer's Avatar
Take off one of your saddlebags and take it to a local auto paint supplier. They will be able to match it for 1/4 the cost of ColorRong.
Don't even TRY to use ColorRong on the Kawi candy reds. A couple of forum members have used their blue from rattle cans and it's worked out fine.... but their clearcoat is not that good.
What I'd suggest for someone not able to spray their own (for colors other than candy reds), use the ColorRite rattle cans for the color coats, then take it to an auto paint shop and ask them to shoot the clear after the color cures for a couple of weeks. That'll give you something heavy enough to buff out the orange peel.
ColorRite is acrylic enamel.
- Rich
2006 1600 Ultra-Classic
Patriot Guard Rider
Old 11-12-2008   #3 (permalink)
Guitar7272
The Widows Son
Extreme Forum Supporter Forum Supporter
Guitar7272's Avatar
Send a message via AIM to Guitar7272
I agree - just take it to an autobody place and ask for a quote. Colorrite is good for a touch up here and there but for a large project with that I'd just see what a local professional could do for me.
2007 mean streak
It's a magical world, Hobbes ol' buddy. Let's go exploring...
October 2008 Member of the Month
Guitar7272 is offline   Reply With Quote
Old 11-13-2008   #4 (permalink)
rival-dealer
rival-dealer's Avatar
would be a bad idea to leave it for a couple of weeks before clear coating ,,too much time for contaminates to build up on the paint ,,get it clearcoated asap ,,,im pretty sure most body shops would be able to match the colour for you
rival-dealer is offline   Reply With Quote
Old 11-13-2008   #5 (permalink)
BrianT
Cruising In Fourth Gear
BrianT's Avatar
Go to the PPG website and check. They have the best paint out there.
BrianT is offline   Reply With Quote
Old 11-13-2008   #6 (permalink)
RichLockyer
I'm referring to when painting the base colors at home with a rattle can.
Not being a true 2-part cure, they need time to offgas or they will cause wrinkling and discoloration of the topcoat.
No, don't put it back on the bike and ride with it... keep it covered and protected (but not with something resting on it).
- Rich
Patriot Guard Rider
Old 11-13-2008   #7 (permalink)
Jambolaya
Can't find time to ride
Jambolaya's Avatar
My auto body shop did a nice job of mimicing the factory blue of the V2K. Two hard bags were $150 done right.
Jambolaya is offline   Reply With Quote
Old 11-13-2008   #8 (permalink)
RichLockyer
That's a good price.
Earl Schieb charged me $100 for a black job that looks like the surface of the moon.
- Rich
Patriot Guard Rider
Old 11-13-2008   #9 (permalink)
airforce1
BUBF
airforce1's Avatar
Yep, the fisheyes are free!
Rattlecan is ok, but a lot of guys aren't skillful with them.
I use my Devilbiss, clean booth, meticulous prep, tack rag, test the mix for temp, assure dry air, dress for the occasion, shoot a test piece, then lay on the color.
Earl is right in the middle of Orange Season just now
Look around, find a bike with a pu$$ paint job on the bags and/or tank and ask, "hey, who did that for ya?"
Word of mouth and experience whips opinions, thanks for sharing your experience.
"time wounds all heels".
Vet,
Patriot Guard Rider
airforce1 is offline   Reply With Quote
Old 11-14-2008   #10 (permalink)
rival-dealer
single pack solvent paints cure in a couple of hours
wrinkling will only happen if paints aint compatable and react with each other
Old 11-14-2008   #11 (permalink)
RichLockyer
Not entirely true.
I've had subsequent coats of the same rattle can paint wrinkle over previous coats. That's why the can says "recoat within 2 hours or after 48"... it's the "after 48" where I've had problems.
Doing a guitar body, I had no problems with color coats, and the first clear coat went on beautifully (same brand rattle can). The 2nd clear coat crazed like it was wrinkle-finish paint. It didn't harm the color coats, and I ended up carefully wetsanding and buffing the clear off and just rubbed out the color coat.
The same brand clear on the bare maple neck... 2 coats didn't craze, but it also never fully cured. Ended up stripping it (which was a PITA because it just balled up in the paper like rubber cement) and using a thinned brushed on acrylic.
- Rich
Patriot Guard Rider
Old 11-14-2008   #12 (permalink)
rival-dealer
Not entirely true.
the problem your having is because of the thinner content in the clearcoat
it causes the dryed clear to react
as for it not drying at all on the other piece there must have been some other clear underneath which was a 2k or something
im a pro painter so if ya have any questions just ask
Old 11-14-2008   #13 (permalink)
RichLockyer
the problem your having is because of the thinner content in the clearcoat it causes the dryed clear to react
How to prevent it? Apply the subsequent coats sooner or later?
- Rich
Patriot Guard Rider
Old 11-14-2008   #14 (permalink)
Jambolaya
Jambolaya's Avatar
What kind of paint do you use if you want to do pin stripes or other shapes on top of the clearcoat?
Old 11-14-2008   #15 (permalink)
RichLockyer
Brush-on pinstriping paint is an enamel and works just fine.
The problem with rattle can paints is the solvents and propellants.
- Rich
Patriot Guard Rider
Old 11-15-2008   #16 (permalink)
rival-dealer
if your doing it wit rattle cans do it soon as possibe
give it 5 mins to flash over
or do it wet on wet
Kawasaki can make you sick. Uncle Bob Off Topic 24 01-15-2009 03:00 PM
Press Release Issued By Kawasaki Motors (January 5, 2005) 2WheelFun Main Lobby 22 09-08-2007 05:36 PM
Survey Results: Kawasaki vs. Suzuki Crazy Dave What I learned today 10 03-23-2007 12:51 PM
Kawasaki Paint SmCollege89 Kawasaki Streetbikes/Sportbikes 1 02-19-2005 08:33 PM
