Can any one help me out? 98 GPX600R engine rebuild
Just striped me motor and am a bit confused as to how To set the cams up cos in the Haynes manual it says when adjusting the cam timing Position No 1 piston at TDC and the IN and EX marks on the cams should be pointing at each other Now that ok as you now where the pistons are in relation to the valves not a problem But cos I’m taking the crank out and the cams out the book says the when reinstalling the cams the marks should be aligned with the machined surface of the cylinder head. So now the IN mark and the EX mark are now facing out would Now if piston no 1 is still at TDC then the timing will be out by 180 degrees Or have I mist something? Any one help |
| High Octane Gas | Migz | Kawasaki Streetbikes/Sportbikes | 10 | 09-13-2009 10:25 AM |
| engine bogged down...one of the cylinder... | kz750maine | The Mechanics Corner | 5 | 08-14-2005 02:35 PM |
| KX250 Engine rebuild: stock vs. Wiseco? | kxshawn | Kawasaki Motocross and Offroad | 2 | 06-02-2005 02:47 AM |
| Engine Running Funny | fireman | The Mechanics Corner | 14 | 04-10-2005 01:47 PM |
| Engine rebuild | UFO8MyCow | The Mechanics Corner | 7 | 04-05-2005 01:27 AM |
