Old 06-03-2005   #1 (permalink)
Doug_S_NC
Question Neutral Switch???
So, this is my first newer bike, with all these safety weitches. 1994 Vulcan 750. The neutral light started coming slightly on in gear, then when I put it in neutral the light flickered and went out. I think I killed it at the same time, not thinking too much about it. Then, next time I turned the key on, I couldnt get the neutral light to come on, I cannot get the starter to do anything. I thought that if the neutral switch went bad, I should be able to bypass by trying to start with clutch pulled in, but still nothing. What do you think?
Doug_S_NC is offline   Reply With Quote
Old 06-03-2005   #2 (permalink)
pitbull76
Cruising In Fourth Gear
Put the kickstand up, pull in the clutch and give it a shot. The bike should not start witht the kickstand down and the tranny in gear, even with the clutch pulled in. Oh, and fix that nuetral switch problem too.
1994 ZX6E
-Mike
pitbull76 is offline   Reply With Quote
Old 06-03-2005   #3 (permalink)
Doug_S_NC
Default Yep, tried that...
So, does that mean you think it might be that neutral switch, luckily on this bike, looks like it is easy to get to.
Old 06-03-2005   #4 (permalink)
pitbull76
It's probably something in that circuit that is messed up. Anyway, try what I suggested and see if it will start. It should. Then you can investigate the nuetral light/switch problem.
1994 ZX6E
-Mike
