Old 07-04-2009   #1 (permalink)
kraaazymike
Unhappy EN500 Stalls on Highways
Hey guys, this is my first post here. I'm hoping you guys can point me in the right direction and give me some ideas.
I bought my Vulcan EN500 new two years ago at a dealership and now has ~6k on the odometer. The other month while riding at around 75mph on the freeway, the engine felt like it lost all power but was still running. Slowly but surely the bike slows down and the engine quits. I pull over to the side of the road. The oil and battery light are on and nothing else looked out of the ordinary so I tried starting it again. It took a few tries to start but it started right up and ran as smooth as nothing ever happened.
I was able to repeat this 4 or 5 times at highway speed and never at any speed lower than 75mph. So after checking the obvious and battery connection, I got to installing a tach to get a better feel for what was going on. I found that if I cruise at ~75mph(6k rpm) the engine will spontaneously drop to ~4.5k rpm. If I loosen the throttle, the RPM's drop by 500 or so in increments until the engine completely dies. Increasing throttle has no effect.
I took it to the dealership as it's still under warranty on June 8th. It's July 4th now and yesterday they told me they can duplicate the problem but can't figure out why it's happening. They checked fuel lines and everything electrical but they're close to giving up. So now they want to charge me the $90 diagnosing fee for my bike that's under warranty for the 5 man hours they spent to tell me they can't fix it.
Anyone got any ideas? I'd appreciate any and all help!
kraaazymike is offline   Reply With Quote
Old 07-04-2009   #2 (permalink)
philipd
Sit speling cheker
philipd's Avatar
Hi Mike,
Welcome to the forum.
I had the same problem you are describing. Mine was caused by a loose battery connection on the negative side. There are actually two screws on the negative side of the battery. One screw comes in from the top and attaches the cable to a metal block. The other screw goes in the side and attaches the block to the battery. The one on the side is VERY hard to see and I only found it because I removed the battery. I tightened it up and no more problem.
As far as the dealer goes: I would fight them tooth and nail over this. It might not do any good and you have to cough up the $90 anyway but I would sure raise a fuss.
Hope this helps.
'09 Vulcan 500 LTD
philipd is offline   Reply With Quote
Old 07-04-2009   #3 (permalink)
kraaazymike
Originally Posted by philipd View Post
Hi Mike,
Hope this helps.
When I get the bike back, that sounds like something I'll definitely look into! I checked the battery but didn't think of taking it out. Thanks!
Old 07-04-2009   #4 (permalink)
Lawn Masters
hates stupidity
I suspect tank vent. next time it happens, open the filler cap and see if you hear a sucking sound. if you do, its the vent being clogged/obstructed somehow and needing cleaning.
ZedX 1k owner. henceforth The bike shall be Zed.
Lawn Masters is offline   Reply With Quote
Old 07-04-2009   #5 (permalink)
BlueNinja14
Big Bear City, CA
BlueNinja14's Avatar
Send a message via MSN to BlueNinja14
My thought too.
If better is possible, then good is not enough!
BlueNinja14 is offline   Reply With Quote
Old 07-05-2009   #6 (permalink)
kraaazymike
Freeways are loud, especially with a full face helmet. But shoot I'll give anything a shot!
Shop said they checked all vacuum lines. But who knows? I'll definitely try it if I ever get the bike back! Thanks!
Old 07-05-2009   #7 (permalink)
Lawn Masters
hates stupidity
the tank vent is in the cap, there are no lines to it. just so you know.
Old 07-05-2009   #8 (permalink)
kraaazymike
Good to know. Probably obvious but I'm a complete beginner to bike wrenching. Fluids, chain and tire maintenance are about as much as I've figured out on these things.
Old 07-05-2009   #9 (permalink)
Lawn Masters
hates stupidity
you'll get good at all of it in time. the EN 500 is the same engine as the EX500, check the ex-500.com wiki for education on how to maintain your engine. very informative.
Old 07-05-2009   #10 (permalink)
BlueNinja14
Big Bear City, CA
" the tank vent is in the cap, there are no lines to it. just so you know."
There are if its a California bike. There is a vapor purge and it has a carbon canister and fuel return pump in the event fuel gets into the system. If the check valves in the fuel cap get plugged or stuck then a vacuum is created in the tank and will cause what is happening to his bike.
Old 07-06-2009   #11 (permalink)
Lawn Masters
hates stupidity
ok true, the cali models are a bit different, so yeah you're totally right.
Old 07-06-2009   #12 (permalink)
BlueNinja14
Big Bear City, CA
I had a 2004 ZRX1200 that had a few mods, one was to remove the smog stuff. I did experience the same problem. I gutted the fuel cap to allow free flow for expansion and fuel draw to the carburetors. My wife's EX500 has the same smog junk but left alone, for now.
Old 07-06-2009   #13 (permalink)
kraaazymike
Is there any specific way to check to see if these things are plugged? I know I'd probably just try blowing on them after disconnecting and seeing if air comes out the other end.
Old 07-07-2009   #14 (permalink)
BlueNinja14
Big Bear City, CA
If you have a vacuum pump you could hook it to the blue labeled line (plug the red one) that goes to the bottom of the fuel tank and see how much vacuum it take before it draws air in. Should be very low vacuum pressure. Here is a link to the ZRX1200 cap I gutted California Gas cap - ZRXOA Message Board
Old 07-08-2009   #15 (permalink)
kraaazymike
Most informative! Thanks!
Old 07-08-2009   #16 (permalink)
kopcicle
obstification engineer
kopcicle's Avatar
Send a message via ICQ to kopcicle Send a message via AIM to kopcicle Send a message via MSN to kopcicle Send a message via Yahoo to kopcicle
Now that the resident pros hit on the easy stuff (and good stuff). I'll just provide a bit of alternate thinking . When were the valves last adjusted ?
~kop
91 KZ1000 POLICE
84 ZN1300 Battlestar Gigantica
79 XS650 Cox Glow Fuel
75 RD 250 Grenade
kopcicle is offline   Reply With Quote
Old 07-10-2009   #17 (permalink)
kraaazymike
~kop
At 600 miles. Owners manual tells me the next one's due at 6000 miles. I'm just under 6k on the odometer.
Old 07-11-2009   #18 (permalink)
kopcicle
kopcicle's Avatar
well then ...
91 KZ1000 POLICE
75 RD 250 Grenade
Old 07-11-2009   #19 (permalink)
Lawn Masters
hates stupidity
thats POSSIBLE, but not likely to be the issue. do you have a fuel filter? I'm also thinking possibly a plugged filter may be at fault. its happened to me before, so its worth considering.
Old 07-11-2009   #20 (permalink)
philipd
Sit speling cheker
philipd's Avatar
So Mike, how much longer is the shop going to have your bike? Heard anything from them yet?
'09 Vulcan 500 LTD
EN500 Stalling when warm bridgstarr The Mechanics Corner 2 04-29-2009 03:05 PM
1984 kawasaki 700ltd stalls armedspudster The Mechanics Corner 4 04-22-2009 02:39 PM
Stalls when putting into gear first time MrWick Kawasaki Cruisers 12 10-09-2007 10:10 PM
List of Arkansas Highways zedx11 Rides, Events and Rallies! 15 01-08-2007 08:16 PM
en500 trouble bodach Kawasaki Cruisers 6 04-10-2006 04:25 PM
