Re-Activated
I am curious how a cooler spark plug works vs the hotter counter part. I have a Mean Streak that uses NGK DPR6EA-9 plugs, but I am considering a cooler plug DPR7EA-9. Will I see any noticable difference between these two plugs? I had heard that the cooler plug may help with some of the noise that the big vulcans have. Is there any negative effects I should consider?
Posting Slacker
![]() Join Date: Nov 2004
Potential fouling.... I went down 2 steps to the DPR8-EIX-9 Iridiums. 2000 miles have not had any problems. They are quieter, but do still have some noise.
I may not have ended up where I intended to go, but I think I ended up where I wanted to be |
#4 (permalink) |
redline
colder plugs are good for racing or nos. unless you run hard alot they will foul .been there. the only noise difference will be missfire. i went with nology silver.moving 1 step should be ok. i went from an 8 to a 10 when i fouled.
