Old 2 Weeks Ago   #21 (permalink)
northernman
My hat is made of tinfoil
northernman's Avatar
Wow have you confused me, you put the petcock on prime to get the gas to flow, then opened the carb bowl drain screws, and are surprised gas flowed out ?
Did I read that right?
Its should flow out.
If you want it to stop leaking tighten the scews back up.
Hug a person that needs one, not some damn tree you fool.
northernman is offline   Reply With Quote
Old 2 Weeks Ago   #22 (permalink)
StarGate
StarGate's Avatar
To Fastpakr: Because, if your float valve isn't sealing good and the petcock is flowing more volume than the drain of the float bowl, the excess fuel will overflow into the cylinder or the airbox and from there it can drain into the crankcase and contaminate your oil.
Mike
Original Owner
1981 KZ1000-K1 LTD
2000 Suzuki King Quad
Refurbish Photos
Old 2 Weeks Ago   #23 (permalink)
Cero
I'll try to explain what I did point to point:
1)Connected a hose at the bottom of each carburator float bowl
2)Run the lower end of the hoses into a can
3)Turned out the drain screw of 2 carburator (not all 4)
4)Turned the fuel tap to the PRI position
...then what happened:
5)Gasoline came out from the hoses connected to the carburators (that's right)
6)A few seconds after i turned the fuel tap on the PRI position fuel started to fall down from the middle of the bike, just under the center stand (it's not right)
is it clear? thanks 4 help
Cero is offline   Reply With Quote
Old 2 Weeks Ago   #24 (permalink)
StarGate
StarGate's Avatar
It sounds like some of the fuel overflowed from the carbs into the airbox and is now running out of the airbox drain line.
P.S. Thats exactly what I described (in my previous post) could happen when you drain the tank in that manner.
Mike
Original Owner
1981 KZ1000-K1 LTD
Refurbish Photos
Old 2 Weeks Ago   #25 (permalink)
Cero
I don't really know. Tomorrow I'm going to:
-Check the tank
-Check carburators
-Check oil and air filters
-Check fuel tubes
-Change engine oil
-Change batteries
-Change (eventually) sparks
after all those operations I'll try to start my Gpz550 after 10 years of garage parking.
Old 2 Weeks Ago   #26 (permalink)
kawpaul
itching to ride
kawpaul's Avatar
Originally Posted by zoro View Post
No problem Cero, glad to help! As for the pope, hes a man like like you and I and does not have the authority to sanctify me or any other human! Only Jesus has that power!
Amen brother, preach on.
1983 gpz 750 .....the wait is over
kawpaul is offline   Reply With Quote
Old 2 Weeks Ago   #27 (permalink)
zoro
GHOSTRIDER
zoro's Avatar
Send a message via Yahoo to zoro
Thank You Paul!Thank God we know the "Truth" brother!
"GHOSTRIDER" 1980 KZ1000ST-E2
zoro is offline   Reply With Quote
Gas gauge on 1500 Classic FI jukief Kawasaki Cruisers 24 12-07-2008 09:40 PM
Fuel leaking from gas tank into engine Paperboy The Mechanics Corner 17 04-13-2006 07:08 PM
Gas getting into air cleaner housing? mmcclish The Mechanics Corner 11 04-12-2006 11:39 AM
how to clean your toilet.... ski Off Topic 12 10-07-2004 05:48 PM
Gas Leak Questions :help!: Type-r 01 886 The Mechanics Corner 3 04-22-2004 10:50 AM
