Hey I have an 89 ex500 and all of a sudden it just started running on one cylinder, which sounds very loud out of one of the pipes and is hard to keep running. I have had the problem with the carbs leaking so I know what it is like flooding the spark plug. However, the spark plugs are clean, the carbs work well, and I am feeling a little warmth from the "so called" inoperative cylinder. The carb bowls fill up and I'm pretty sure there is gas going into the cylinder, however it is still running rough and very loud and a lot hotter from the good cylinder. I guess I'm asking if anyone has any clue or hints on what it could be. I was thinking maybe about the mixture ratio maybe lack of air? Or timing? I was riding it, then two hours later I tried to fire it up and it went right to one cylinder. THanks in advance for the help guys!
-colin |
#4 (permalink) |
Banned
Might want to test the spark plug and wire on the appropriate side, make sure it's still firing. It's possible to have one coil go bad on those. And make sure the plug didn't back itself out of the cylinder, I had one do that to me on the highway once. Wouldn't run without a lot of throttle input. Lots of dumb little things can make these bikes start running on one cylinder. Also try closing down the pilot jet on that side, might have vibrated open and it's flooding a bit. The jet adjusters have caps on them from the factory, if yours does not then it's a good bet the bike has a jet kit. The adjusters are right over the top of the starter and in the vertical plane. The screws that stick out the sides are the float bowl drains....
#6 (permalink) |
Sit speling cheker
You could pull the airbox and shoot a LITTLE starting fluid in the dead carb with the enging running. See if it fires.
I had a 500 and always had trouble with the carbs plugging up. Finally did the liquid tank liner and installed an inline fuel filter. Didn't have trouble after that.
1988 ZX10, Vance & Hines SS2R exhaust, stage 3 jet kit, K&N filters. Like I needed another project! |
