2002 Vulcan 1500 Fuel Pump / FI not getting power
+ Reply to Thread
Results 1 to 5 of 5
Thread: 2002 Vulcan 1500 Fuel Pump / FI not getting power
  1. #1
    Join Date
    Aug 2010
    Posts
    6
    Default 2002 Vulcan 1500 Fuel Pump / FI not getting power
    Thanks in Advance, yall D'best mechanics I know!
    Bikes sat 2 years after back surgery, cleaned fuel tank, fuel pump (works with direct power)
    No FI light when keyed on
    Power to white/red wire only on relay
    Changed with working relay, still same
    Battery terminals cleaned, wires under seat jiggled/checked for connectivity
    Any ideas where to go from here? Ignition switch, diode. ecu?
    Thanks
    Drifter Joe
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #2
    Needs A Real Job BTK Expert
    Join Date
    Mar 2009
    Posts
    2,898
    Default Re: 2002 Vulcan 1500 Fuel Pump / FI not getting power
    Did you try to start the bike before you cleaned tank, etc?
    What was the problem at that point?
    Does it now crank/no start or ???
    Does the fuel pump run with initial key on?
    What is the battery voltage, key on?
    Do the running lights come on?
    Post back.
  4. #3
    Join Date
    Aug 2010
    Posts
    6
    Thanks Sfair,
    No fuel pump power at relay, No FI light
    starter turns over, no fuel
    didnt try bike before tank and pump cleaning, bike worked when parked
    battery voltage 12.34, and yes the running lights come on.
    tried new relay from sister bike, no help....tried existing relay IN sister bike relay faulty running bike would not power fuel pump. So I have 2 problems,a bad relay and Im thinking maybe the ecu or diode not opening relay.
    Joe
  5. #4
    Join Date
    Mar 2009
    Posts
    2,898
    Could you do this test:
    Key on, take voltage reading on all four wires of fuel pump relay and post back. Be sure and take the readings at the instant the key is turned on. Repeat the key on procedure if you cannot do all four within a couple of seconds.
    Is 12.34v the battery voltage, key ON?
    Post back.
  6. #5
    Join Date
    Aug 2010
    Posts
    6
    Thanks I traced a short to the fuel pump assembly, used heat shrink on all fittings in tank and bike running now.........New Problem, please see next post on clutch issue ;(
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. 2001 Vulcan 1500 Classic Fuel Pump Problem
    By boogeyman in forum The Mechanics Corner
    Last Post: 09-28-2010, 07:45 AM
  2. 1500 Drifter Fuel Pump Fix
    By DrifterJoe in forum Kawasaki Cruisers
    Last Post: 08-26-2010, 08:41 PM
  3. 2003 Drifter Fuel Pump on 2002 Mean Streak
    By Udet109 in forum Kawasaki Cruisers
    Last Post: 08-04-2010, 09:32 PM
  4. 1988 vulcan 1500 a2 fuel pump question
    By telnetech in forum The Mechanics Corner
    Last Post: 03-28-2010, 10:37 AM
  5. 2002 Mule 3000 Fuel Pump question
    By mcoplin in forum Kawasaki ATV and Mule
    Last Post: 04-10-2009, 05:34 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
