2004 Kawasaki Bayou 250 will start, but not keep running when I let off the START button.
+ Reply to Thread
Results 1 to 2 of 2
Thread: 2004 Kawasaki Bayou 250 will start, but not keep running when I let off the START button.
  1. #1
    Join Date
    Feb 2011
    Posts
    1
    Default 2004 Kawasaki Bayou 250 will start, but not keep running when I let off the START button.
    I just picked up 2004 Bayou 250 with very low hours. It has been sitting for at least 4 years, with a cracked case around the oil drain plug. I was able to repair the drain plug, but when I try to start it, It fires right off when I push the starter button, but when I let go of it, it stalls. Again, when I restart it, and hold the button in and keep it in it will run. But again, as soon as I let go it STALLS! ! ! ! H E L P, P L E A S E ! ! THANKS.
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #2
    RCW
    RCW is offline
    Needs A Real Job BTK Expert
    Join Date
    Nov 2007
    Location
    Oregon, Chile, Alberta, Texas
    Posts
    3,781
    Default Re: 2004 Kawasaki Bayou 250 will start, but not keep running when I let off the START button.
    Check your fuses and the relay assembly, and the connectors from the key switch all the way through to the ignition module. If the main relay does not switch correctly the ignition will feed power through the starter relay, same thing if one of the connectors to the Igniter or the Voltage Regulator is corroded, then when the starter button is released the power drops.
    If toys will get me in the door when it is time to go, I have it made!
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. 96 Kawasaki Bayou 220 Electric Start
    By Bigmanlittlebik in forum Kawasaki ATV and Mule
    Last Post: 03-29-2010, 01:25 AM
  2. HELP! Kawasaki bayou won't start, something to do with broken reverse
    By Kazik wolf in forum The Mechanics Corner
    Last Post: 07-23-2009, 07:39 AM
  3. 1990 Bayou KLF 300c 4x4 will not start/stay running
    By fb0226 in forum Kawasaki ATV and Mule
    Last Post: 07-07-2008, 06:05 PM
  4. ZX7 Start Button
    By 2001_ZX6R in forum The Mechanics Corner
    Last Post: 01-02-2008, 03:48 PM
  5. 1988 Kawasaki Bayou 300 2x4 wont start
    By mk9shepherd in forum Kawasaki ATV and Mule
    Last Post: 10-06-2007, 10:37 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
