Horn polarity.
+ Reply to Thread
Results 1 to 3 of 3
Thread: Horn polarity.
  1. #1
    Sit speling cheker BTK Expert
    Join Date
    Sep 2008
    Location
    Littleton, NH
    Posts
    439
    Default Horn polarity.
    Aftermarket horns show no polarity markings on them. I have the wiring schematics for my bike which show brown wires (hot side) and black/white wires (go back to the horn switch - ground on other side of horn switch [yellow/black]). There is no continuity from either terminal on the horn to the horn case. Does it simply not matter how they're connected?
    1981 KZ1000-K1 LTD (wishing it was an 80')
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #2
    No Significant Other BTK Expert MFolks's Avatar
    Join Date
    Jul 2008
    Location
    Springfield Mo
    Posts
    10,117
    Default Re: Horn polarity.
    Most kawasaki horns work by having the voltage go through the horn when the button is pushed. It acts like giving the horn a ground. What brand of after maket horn are you going to use? I'd try them with a battery first before installing them, also because after market horns can draw a lot more current than what you had, I'd get a relay to prevent the horn button from burning out.
    Ear Cannon Air Horn :: Aerostich/RiderWearHouse Motorcycle Jackets, Suits, Clothing, & Gear is one type of loud motorcycle horn, and here's more relay information:
    Relay Types& Wiring Information
    Single Pole Double Throw (SPDT), Single Pole Single Throw (SPST) Automotive Relays
    How to Check a Car Electrical Relay and Wiring Circuit Test - 2CarPros
    http://www.summitracing.com/parts/PCO-5591PT/
    MCM Audio Select Relay Socket 5-pin For Bosch Type Auto Relay | 26-1942 (261942) | MCM Audio Select
    Mike Folks
  4. #3
    Join Date
    Sep 2008
    Location
    Littleton, NH
    Posts
    439
    Yup, should have just tried hooking them up to a battery. Just like you said MFolks. They work wired either way. Thanks.
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. horn or no horn?
    By desertmule in forum Kawasaki ATV and Mule
    Last Post: 06-16-2005, 08:15 PM
  2. Plastic Horn Blows
    By 1600v-twin in forum Kawasaki Cruisers
    Last Post: 03-13-2005, 05:36 PM
  3. Horn Cover for 1600 Classic
    By Freedom1600 in forum Kawasaki Cruisers
    Last Post: 11-14-2004, 08:12 AM
  4. Yamaha & Kawasaki Billet Starter & Horn Buttons
    By Cycle-Parts in forum Accessory Swap Meet
    Last Post: 04-24-2004, 11:38 PM
  5. My horn wont toot!!!!!!!
    By okbow68 in forum The Mechanics Corner
    Last Post: 04-15-2004, 12:19 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
