Ok this bike has fought me ever since i bougt it. Ok so far I have redone the carb put new intake valves in(originals were cut and sucked up into the head. After these two fixes the bike ran great. Over the wkend i took it to a local race. During the time i came off a jump and then went into a turn and the engine(i think) let out one loud tink. After that it lost power. You can ride it for about 10 secs then it shuts down. The engine now has developed tinks that come from the engine.(I think) I have no clue what is wrong unless it is just over heating. If anyone has any ideas can you please help.
Third Gear And Gaining
what bike is it? year and so on.
just off the top of my head, maybe a retainer wasn't set properly on a valve and now it's just floating, hitting the piston.
'03 Ninja 500R, all stock. |
#4 (permalink) |
Banned
Do a compression check, wide open throttle...safety switch turned to off... when you crank it over to prevent damaging the ignition system...see if things are equal...if they arent then pull the head and check the pistons closely for cracks, and check the head gasket as well, real close on both of them. worst case pull the jugs and see if the pistons, rings, wristpins, wrist pin rings, rods, bearings...you know the drill...it is possible that one of the valve springs broke, circlip came of or even a retainer ring is bent...let us know...that is part of the FORUM!!!
#6 (permalink) |
Banned
Take it apart...the uncertainty is killing us...no sense getting a new motor, yet, since you don't know what you have inside...like rednek426 said it could be just a retainer spring from a valve...there isn't much inside that can go wrong...that will destroy it...so take it apart and let us know!!!
| 95 500 Ninja... Power Loss? | Jasonx | The Mechanics Corner | 9 | 01-17-2007 03:26 AM |
| Power loss problem help needed | Driftin toad | The Mechanics Corner | 6 | 10-30-2006 07:05 PM |
| new owner/member power loss | 2ndgear | Main Lobby | 2 | 11-04-2004 10:39 AM |
| prairie 650 power loss | turnerman | The Mechanics Corner | 16 | 10-21-2004 10:15 AM |
| loss of power?? | Wolffman | The Mechanics Corner | 1 | 03-05-2004 12:47 PM |
