Old 05-16-2004   #1 (permalink)
ZX-Jay
Default ZX-6E carb rebuild
Hi,
I own a 1995 ZX-6E with 103,000 miles. I believe it's time for a carb rebuild. Basically, the engine seems to be flooding during cold starting (I can smell gas sometimes, and the smallest amount of choke will prevent the bike from starting at all; also, I used to get approx. 200 miles per tank during highway travel. Now I'm only getting 150 miles). There's a catch, though. When cold-starting the bike on it's side-stand, the engine doesn't seem to flood. It's only when starting the bike when it's upright (e.g., on its centerstand) that it seems to flood. In any case, when the bike is warmed up, it seems to run fine, except for the low mileage.
Well, my question is, given these symptoms, which replacement carb parts should I buy? I know that sounds like a ridiculous question, because I'm sure most of you out there will say that you'd have to crack open the carbs before you could tell me. The thing is, the bike is my only transportation, so I can't spend weeks waiting for the parts to arrive while the bike sits idle. I have to take a reasonable guess as to what I'll need before working on the bike, so I can attempt the repair in a day or two.
Given my bike's symptoms, will I most likely be OK with just getting a simple repair kit? If you were me, would you also order new main jets and new floats? (new floats are expensive though-$100 for 4; and are floats normally something that ever go bad?) Are there any other parts you would order beforehand?
Viele dank to anyone who responds.
Jason
ZX-Jay is offline   Reply With Quote
Old 05-19-2004   #2 (permalink)
ZX-2R
Banned
Send a message via AIM to ZX-2R
Default JASON
Try to chat with the mechanic at the shop and tell him your situation,,,it's your only transportation...you may have to take it in on a saturday to get the job done, or you may be able to get around the system and have the mechanic come over like after work Saturday, for a steak dinner or out to his favorite resturaunt once the carbs are rebuilt. MAYBE you can find several people in your area that are carb guru's and can fix you up right on the spot at their house. Look in the Profile section and see who is close by and ask them. Bottom line though is that you are killing the dealership of a source of income that keeps them open for all of us...IF you can afford to get it done at the dealership then do that as your point of action...that way you won't feel guilty when the dealerships get smaller and we no longer have any to go to...with the cost of gas/petrol going up///you should get it done soon!
ZX-2R is offline   Reply With Quote
anyone know where to get a carb and head rebuild kit online? AkieNine The Mechanics Corner 2 05-04-2006 12:54 PM
Wanted: Carb Rebuild Kits for 1981 Kawasaki 750 kz Doughboy1993 Accessory Swap Meet 2 09-21-2005 11:00 PM
carb rebuild kit question 95Zx6r The Mechanics Corner 2 08-06-2005 02:49 AM
Carb Rebuild Kit duckfan Vintage Motorcyle Info 7 01-12-2005 07:57 AM
carb rebuild help fenny777 The Mechanics Corner 0 02-22-2004 12:59 PM
