Old 05-21-2004   #1 (permalink)
Jacobsen
Default Air pressure fwd schock absorbers gpz1000RX
Anyone able to tell me the pressure in fwd absorbers on a gpz 1000 RX
Jacobsen is offline   Reply With Quote
Old 05-22-2004   #2 (permalink)
Lucas
Default re air pressure
Jacobsen
should be between 5.7 - 8.5 psi
they say 7.5 psi is about the best
Lucas
GPz1000RX, GPz900R
Lucas is offline   Reply With Quote
Old 05-24-2004   #3 (permalink)
Jacobsen
many thanks for the the answer
Old 05-06-2005   #4 (permalink)
batty
Hi, due to the lack of a main stand because of 4>1 exhaust I am unable to check the pressure with weight off the forks on my gpz1000rx
Does anyone know what sort of higher pressure reading i would need to set at to compensate?
Any info or help much appreciated
batty is offline   Reply With Quote
Old 07-24-2006   #5 (permalink)
robgosty
Anyone come up with an answer, i have same problem 84 GPZ750R, no centre stand, no "skyhooks" about. I know that this is old thread but its all search could find related to fork air pressure.
Many Thanks Rob
robgosty is offline   Reply With Quote
Old 07-24-2006   #6 (permalink)
elr658
Eddie Lawson is God!
elr658's Avatar
Robbo, replace sacked fork springs with Progressive Suspension (or the local equivalent) go up to 10-15 wt fork oil and FORGET about the air.
1982 Kawasaki KZ1000R1 #658
1983 Honda CB1100F Blue.
www.myspace.com/79cb750f
Old 07-25-2006   #7 (permalink)
robgosty
Thanks for answer, that seems to be the way forward so thats what i will do
Once again ,many thanks
Rob
Constrictor's Caddman Air Mod Tutorial (56k Warning) Constrictor Projects and "How To" Write Ups 265 10-09-2009 09:22 AM
Air pressure for 1500 jukief Kawasaki Cruisers 31 04-04-2007 02:27 AM
MeanStreak air pressure question Mangler Kawasaki Cruisers 8 08-30-2005 07:16 PM
GPZ1000RX fork air pressure batty Vintage Motorcyle Info 1 05-08-2005 12:19 PM
What do use adjust the air pressure in the rear shock on my fozy The Mechanics Corner 1 04-07-2004 01:30 PM
