Old 01-03-2006   #1 (permalink)
Angelus
Default OIl Change Problem
After some advice please.........
Just done my first oil change on my ZX6R J1 X-plate and the problem I have is the stupid oil light will no longer go out !
Anyone else had a similar problem and know of a remedy please.
I have removed the pressure switch and cranked it over but no oil coming out there and yes there is oil in the motor
Angelus is offline   Reply With Quote
Old 01-03-2006   #2 (permalink)
zedx11
yellow doesn't corner wel
zedx11's Avatar
Send a message via Yahoo to zedx11
make sure the wire going to the pressure switch is connected or has no brake in the line. your switch could be bad if there is nothing wrong with the wire.
Darrell
Ignorance is a disease my friend. You should rid yourself of it.
zedx11 is offline   Reply With Quote
Old 01-03-2006   #3 (permalink)
Angelus
Had the switch removed and there is no oil getting to that either when crackin the engine over
Old 01-03-2006   #4 (permalink)
Angelus
Does the oil filter have a valve in it ? perhaps that is defective ?
Old 01-03-2006   #5 (permalink)
southjersey636
Way Too Much Free Time
southjersey636's Avatar
Send a message via AIM to southjersey636
back out the filter a little bit, then tighting it up and see if it goes off, you most likely got air trap between the filter, this is a common problem.
2004 Kawasaki ZX6R 636
1995 Kawasaki 600R (old bike)
1991 Plymouth Laser
southjersey636 is offline   Reply With Quote
Old 01-04-2006   #6 (permalink)
Angelus
Do you guy's fill the filter before fitting it ?
Old 01-04-2006   #7 (permalink)
Angelus
The future's bright, the future's burping Worked a treat
Started bike, turn filter off 2 turns till I saw a wee bit of oil strat to push through then re tightned it, all sorted full oil pressure back and one happy bunny to boot
Old 01-04-2006   #8 (permalink)
southjersey636
lol, glad to hear it worked.
1991 Plymouth Laser
Still need help with Oil problem. j0njp The Mechanics Corner 2 10-06-2005 11:42 PM
Winterizing...change oil before storage? luvda6R Main Lobby 7 10-06-2005 10:42 PM
Meanie 2500 mi Oil Change - Need To Change Oil Filter Too? TMac Kawasaki Cruisers 6 05-31-2005 07:23 AM
Kawasaki Vulcan leaking oil after oil change J-Alan Kawasaki Cruisers 0 09-15-2004 05:36 PM
idle speed, check battery, and oil change BradPeart What I learned today 1 05-03-2004 01:54 PM
