2000 Kz 1000p - Kawasaki Motorcycle Forums
post #1 of 7 (permalink) Old 04-18-2017, 05:32 PM Thread Starter
Junior Member
2000 Kz 1000p
I never noticed but does or should my brake light get brighter when using foot paddle it does with using hand brake
guermike is offline
Sponsored Links
Advertisement
post #2 of 7 (permalink) Old 04-18-2017, 06:43 PM
Senior Member
martin-csr's Avatar
Yes. There is a brake light switch at the Rr brake pedal. a spring connects the two. The switch probably has an adjusting nut on it & a couple of mounting nuts. On my 81 KZ650 the manual has a warning to make sure the switch body does not turn during adjustment, so that the connections inside the switch don't get damaged.
martin-csr is offline
post #3 of 7 (permalink) Old 04-18-2017, 10:29 PM Thread Starter
Junior Member
OK thanks I will check it out
guermike is offline
post #4 of 7 (permalink) Old 04-19-2017, 07:17 PM
Senior Member
martin-csr's Avatar
The owner's manual may have instructions on how to adjust the rear brake pedal & brake light switch.
post #5 of 7 (permalink) Old 04-21-2017, 01:24 PM Thread Starter
Junior Member
Thanks just like you said got it working, how hard is it to replace intake boots
guermike is offline
post #6 of 7 (permalink) Old 04-22-2017, 05:11 PM
Senior Member
martin-csr's Avatar
Do you mean the airbox ducts? If they are soft, it should be easy.
On my 81 650 I sometimes just push them into the airbox & reinstall from inside the airbox.
Often times it's suggested to remove the airbox bracket bolts to get a little wiggle room, but I never bother doing that.
If they're hard, you could cut them out. avoid damaging the airbox. A heat gun might help soften hard ones for removal.
I'm not sure if a heat gun could ignite gasoline, though.
post #7 of 7 (permalink) Old 04-22-2017, 08:43 PM Thread Starter
Junior Member
OK thanks for the help
guermike is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
You may post new threads
You may post replies
BB code is On
