Old 01-15-2006   #1 (permalink)
phil olseb
Default How do I check saftey switch???
I have a 87 705R that stalls if I let the clutch lever out more than half way. I have been told it could be the switch on the kickstand or clutch, how can I check these switches?
phil olseb is offline   Reply With Quote
Old 01-16-2006   #2 (permalink)
zedx11
yellow doesn't corner wel
zedx11's Avatar
Send a message via Yahoo to zedx11
do you know how to use a multimeter.
Darrell
Ignorance is a disease my friend. You should rid yourself of it.
zedx11 is offline   Reply With Quote
Old 01-16-2006   #3 (permalink)
Scruffy
Scooter Trash!
Scruffy's Avatar
Don't even waste any time with a multimeter. Cut both sets of wires, and twist or solder the ends leading into the bike together. You don't need the switches. They just fail on the road when you least expect it.
Mine have been deleted (before I bought the bike). I just make sure it is in N by rolling it a tad, turn on the key, and hit the button. No need to pull in the clutch.
-Scruffy
Eagle Scout. Veteran. Patriot Guard Rider.
1950s style Savage barhopper
1950s style VN800B bagger
Scruffy is offline   Reply With Quote
Old 01-18-2006   #4 (permalink)
JimFitz
Delorean Mechanic
JimFitz's Avatar
Sounds like the kick stand switch. I would doubt the clutch switch.
You can by-pass it like Scruffy said and that will tell you what you want to know. If you want to make it work again, then you can get another at the Kaw store and reinstall it.
Good Luck
Jim
JimFitz is offline   Reply With Quote
Check - Double Check - Triple Check. Tazzzie_ What I learned today 13 06-24-2005 12:13 AM
03 Prairie 360 4X4 Belt Fault Switch jlively Kawasaki ATV and Mule 2 10-25-2004 06:27 AM
pre-ride check list!! bikeaholic What I learned today 13 06-03-2004 08:10 AM
7,500 mile scheduled maintenance, HELP! BradPeart Kawasaki Streetbikes/Sportbikes 3 04-25-2004 06:22 PM
How to change oil on 99 ninja 500R mixery2k The Mechanics Corner 8 01-22-2004 07:49 PM
