LinkBack | Thread Tools |
Finally Got Into First Gear
This morning my bike went down. Long story short, the end of my clutch lever busted off. How do I remove the lever?
Also, when I choke, my engine dies. Why is this happening? Any help is appreciated. Thanks.
2002 Kawasaki Ninja 500R FOR SALE 1999 Chevrolet Camaro FOR SALE |
#3 (permalink) | |
Third Gear And Gaining
Enjoy, T.L. Wisner AMA SCRC COG VOL '94 Kawasaki ZG1000 Concours '05 Suzuki Boulevard C50 '02 Suzuki GZ 250 "If That Phone Was Up Your Butt, Maybe You Could Drive A Little Better..." |
#4 (permalink) |
Banned
When you use the choke you are basically cutting off a majority of the airflow. YOu should only use partial choke long enough to start the bike (unless you dont need to) as the Owners Manual states. Once the bike starts the choke should be redused or completely turned off and you should blip the throtle a couple of times to clear the unbunt gass or you will foul oyur plugs. People often start having problems with their bike starting,,,90% of the time is is because of the plugs...et an extra set and soak them in white inegar overnight and the n blow them dry and you will have an extra set for the next time you need to change them out. YOur local dealer should have theclutch lever...but Beartooth has them at a discount...
| Clutch Lever Adjustment | mrl250 | Kawasaki Streetbikes/Sportbikes | 7 | 09-17-2007 02:09 PM |
| Clutch lever play vanishes | stephen | Main Lobby | 2 | 11-01-2005 08:12 PM |
| Clutch lever play vanishes | stephen | The Mechanics Corner | 0 | 10-27-2005 09:22 AM |
| Problem with my clutch lever | bigox0417 | Kawasaki Streetbikes/Sportbikes | 0 | 10-16-2005 11:42 PM |
| Adjusting clutch lever | jukief | Kawasaki Cruisers | 29 | 03-31-2005 12:20 PM |
