Old 03-09-2006   #1 (permalink)
Willys
Willys's Avatar
Default 1998 EX500 ninja, Engine problems???
Hi guys:
I'm in need of some tech help..I have a 1998 EX500 Ninja. It has roughly 1000Kms on it, it has been sitting for the last 4 years. I have rebuilt the carbs using carb cleaner and high pressure air blown through all orfices(holes lol), cleaned the tank,fuel ****,filter,air cleaner assembly, put in high test gas, new plugs, checked for spark,fuel,compression...is low on one cylinder about 130psi(left side). I added some oil to check for worn rings etc and it increased it slightly. This engine has just under 1000 kms original.
OK...the problem is...it won't fire on the left side unless beaten on the street??? Then it will kick in BIG time!!! BUT...the left side will not fire at idle or any revs.
I am wondering if the rings could be stuck in their grooves from sitting or the valves are sticking from sitting....Is this a possibility???
I have an idea to put transmission fuild in the cylinder and crankcase to loosen these areas up ...???
Has anyone else out there had anything similar and used tranny fluid to help loosen the rings, valve train???
I am wondering if this proceedure will harm any components???
I don't want to take this engine apart just yet if at all possible as it doesn't make any sence that it will be a severe mechanical problem as there is no mechanical knock or noise of any type coming from the engine when running on one cylinder or even on two when it does fire on two.
Can anyone offer any help ????
Thanking you in advance
Willys[]
Willys is offline   Reply With Quote
Old 03-11-2006   #2 (permalink)
Willys
Willys's Avatar
Talking
Hi guys:
Well I finally got it to work!!!!
It seems that the Pilot jet was still dirty!!!
Once I spent a couple of more hours redoing what I thought I had done the first time it now runs fine....lol
Thanks for all your help and advice!!!
Willys
Willys
1998 EX500 Ninja
2006 Toyota Echo
1952 Willys/Overland Pick-up
potential problems on a 1998 kawasaki ex500 with 15K miles sam_j Kawasaki Streetbikes/Sportbikes 8 03-09-2006 04:26 PM
FS: 2000 Ninja 500R + extra engine and lots of work leftovercrack Streetbikes Buy/Sell/Trade 0 11-24-2005 03:09 PM
Problems starting ex500 j0njp The Mechanics Corner 10 03-23-2005 07:16 PM
Stupid carelessness (Ninja 500 1998) deadseasquirrels Kawasaki Streetbikes/Sportbikes 10 12-14-2004 10:49 PM
1998 Ninja EX500 - FS zr2gal Streetbikes Buy/Sell/Trade 3 03-30-2004 12:21 PM
