Old 04-21-2006   #1 (permalink)
Jutboy
Default If you drop bike or change oil and oil pressure light is on **SOLVED**
Hey guys I just wanted to share this little trick with you that solved my down ed bike problem
It's called Burping and I'm going to quote MadViking.
After you change the oil in your motocycle, it is possible for an air pocket to form that will prevent oil from circulating thoughout the engine. You will know this has happened if your oil warning light is ON and/or the engine is much noisier than usual.
Place a trash bag or rags down underneath the engine. Start the engine and then loosen the oil filter just enough for oil to spray out. I placed a cup directly under the filter and was able to not spill any. Then, recheck your oil level and add as necessary.
I had this happen to me. After changing the oil, I started it and the engine sounded like a diesel. After burping the filter, the engine immediately ran quieter and the oil warning light went OFF.
Thanks for your help before with it
Jutboy is offline   Reply With Quote
Old 04-22-2008   #2 (permalink)
jhester
My V900!
jhester's Avatar
Thanks for the info might have to remember that!
2006 VULCAN 900 CLASSIC!
jhester is offline   Reply With Quote
Old 04-23-2008   #3 (permalink)
antiq
Vintage bike addict
antiq's Avatar
I'll have to file that.
82 KZ750LTD, 84 Virago 700, 85 Vulcan 700.78 KZ750 twin,82 KZ650, 77 KZ650, 75 CB200T,Vince
antiq is offline   Reply With Quote
Old 04-27-2008   #4 (permalink)
El Mexicano
Your future ex-boyfriend
El Mexicano's Avatar
Send a message via Yahoo to El Mexicano
Great! I had a similar problem with a car and the coolant, I did something like that and it worked. I will make a note of this.
- Sergio
'07 VN900 Classic LT
VROC #26960
Proud SoCal Wild Snail
El Mexicano is offline   Reply With Quote
Old 12-06-2008   #5 (permalink)
bbacsc
Thanx alot changed my oil today had a noise. This thread saved me alot of headaches.
bbacsc is offline   Reply With Quote
Ways to drop your motorcycle Freakinout Main Lobby 174 10-14-2009 02:58 AM
Dropped Bike - Now oil light is on.... Jutboy The Mechanics Corner 2 04-11-2006 08:09 AM
Oil Pressure Light wubba The Mechanics Corner 4 07-03-2005 09:51 PM
Oil change. Now Oil light on, HELP!!! DaveinNM Kawasaki Cruisers 3 09-28-2004 11:50 PM
oil change, Now oil Light on, HELP! DaveinNM The Mechanics Corner 5 09-04-2004 11:55 PM
