Old 04-24-2006   #1 (permalink)
tanktime
Default '98 zx7r starting problem
Hello everyone, my problem is this. I have a '98 zx7r ninja which starts fine cold. However, when I let it run to the point where it is around normal orperating temperature and shut it off, it doesn't want to start after that. For instance, I started it yesterday and let it run for a while then shut it off and I wasn't able to start it again until this morning. The battery is new, the fuses are all good and when the bike is cold, it starts up just fine. But when it warms up, the starter doesn't turn over at all. I can hear what I think is a single click coming from the starter relay, but thats it. If anybody could please help me in letting me know where to start looking for the problem or how to find the problem I would greatly appreciate it. Thanks
tanktime is offline   Reply With Quote
Old 04-24-2006   #2 (permalink)
Ericthejet
Forensic Bug Splatter Analyst
Ericthejet's Avatar
I would double check the condition of the battery despite being new.
1984 Ninja 900 (A1)
To make it go faster I need to add more lightness!
Ericthejet is offline   Reply With Quote
Old 04-24-2006   #3 (permalink)
Superfly
Rippin Ninja's heads off!
Superfly's Avatar
Sounds like a charging system problem to me. The click tends to mean that the battery does not have enough juice to turn over the starter, maybe because the charging system went down, and you are running off the power of the battery, as you let the bike sit, the battery's voltage goes up to the point where you can start the bike.
Get a voltage meter, put it on the terminals of the battery, take a reading (12.5 volts plus or minus), start the bike, and then put the meter back on the terminals of the battery. You should have between 13.7 - 14.5 volts.
Or the starter is going out.
Superfly is offline   Reply With Quote
Old 04-24-2006   #4 (permalink)
tanktime
thanks for the repies. I will be getting a volt meter within the next day or so to test the battery. until then any and all suggestions are welcome!!!
Old 04-27-2006   #5 (permalink)
tanktime
ok, so I checked the battery and the voltage was a little over 12.0 (around 12.1 to 12.2) and I just started it up and after I shut the bike off the battery was fully charged (12.5v). Also while it was running I checked the voltage from the alternator and at idle it was around 13.0 and when I would rev it to around 3000 rpm it went up to around 14.0. So according to this I am assuming that the charging system on the bike works, however once again after it got up to normal operating temperature the bike would not start after I shut it off. So now I'm thinking it's the starter??? Also after seeing that the voltage stayed up I checked the starter for any visual signs of wear and the wire coming from the starter that goes to the starter relay was sliced open in one spot exposing the wires. Would this have any affect on the starter after the bike warms up? Once again, any and all suggestions are greatly appreciated.
Old 04-27-2006   #6 (permalink)
Superfly
Superfly's Avatar
Do any of the Ninja's suffer from Vapor Lock?
Old 04-27-2006   #7 (permalink)
tanktime
I'm sure they could, however I don't think that would prevent the starter from turning over. But then again, I could be wrong.
Old 04-28-2006   #8 (permalink)
Ericthejet
Ericthejet's Avatar
When it gets hot after running the starter won't engage?
1984 Ninja 900 (A1)
Old 04-28-2006   #9 (permalink)
Ericthejet
Ericthejet's Avatar
PS. Check those sliced wires. Are they bare? Re-wrap them.
1984 Ninja 900 (A1)
Old 04-28-2006   #10 (permalink)
tanktime
Yeah, after the bike warms up the starter won't turn over at all, the lights come on and I checked the battery after letting it run for a few minutes to warm up and the voltage was at about 12.5v, so I believe that means the alternator is working. As for the wires I will wrap them up to see if maybe that helps at all.
Old 04-28-2006   #11 (permalink)
Ericthejet
Ericthejet's Avatar
Might be a lnog shot but perhaps the heat the started absorbs binds the internal workings and keeps it from turning with the available amps. coming from the battery. Does that bike have a starter clutch and chain?
1984 Ninja 900 (A1)
Old 04-28-2006   #12 (permalink)
tanktime
well, i just a couple more tests and here is where i'm at so far. I took the wire that runs from the starter to the starter relay; disconnected it and put it directly to the positive battery terminal to see if it would turn over and it does! Because of this I'm thinking that the only thing left is the starter relay switch which has three wires; white=positive battery, yellow=clutch switch and black=ground. So I checked the white wire with a circuit tester and there was power going to it. Then I checked the yellow wire and I did not get any current going to it. Does this mean that the clutch switch is bad or malfunctioning and should I start to trace the wire back to make sure it is ok as well as the switch itself? I feel like I am getting closer to the problem, I just would like to see if I am going about this the correct way.
Old 04-30-2006   #13 (permalink)
spdrkt ZX7R
Can't find time to ride
spdrkt ZX7R's Avatar
Send a message via Yahoo to spdrkt ZX7R
7R's are notorious for the safety switches coming loose, going bad, or just being corroded. Check the switch on the sidestand (putting the two wires together on the bike side of the switch will defeat it) and the switch on the clutch. Also clean the contacts of these switches and the starter relay with some emery board and some isopropyl alcohol. I bet your problems will go away.
There is nothing ZX about an EX!!!!!!!
ZX7R Worldwide Site
Buymoto
spdrkt ZX7R is offline   Reply With Quote
starting problem ZL400 paolov Kawasaki Cruisers 4 09-27-2006 02:45 AM
Cold starting problem jesse1 The Mechanics Corner 4 05-03-2005 12:23 PM
Strange Starting Problem With 2002 1500FI lylemills Kawasaki Cruisers 1 04-11-2005 09:46 PM
Starting problem with Vulcan 750 KHMERGUY Kawasaki Cruisers 1 03-02-2005 07:45 PM
Another starting problem, VN750 wilythek Kawasaki Cruisers 12 10-20-2004 04:24 PM
