Old 04-29-2006   #1 (permalink)
Superfly
Rippin Ninja's heads off!
Superfly's Avatar
Default 89 zx600R Valve Adjustment
I am trying to adjust the valves on the bike, and I have run into a snag. When I got the bike, the bike was not timed, so I followed the Manual (clymer). The problem is that when I am trying to check the clearances, #2 pistons exhaust valve is partially depressed. The manual was not crystal clear on this, so I might have a timing problem.
I set the timing like this:
I turned the crankshaft untill the mark on the rotor "T" (there is a "T", "F", "1" & "4" all together) was aligned with the timing mark on the engine. I set the camshafts (in & ex) facing away from each other, and counted of the 42 camchain pins to complete the timing, as per the manual. But in this position, the #2 piston exhaust valve is partially depressed. Something is wrong here...
Now when I turn the engine over a full turn, all the valves I need to check are not depressed. Anybody have this happen to them? and should I check the clearances like this?
Any help would be greatly appreciated!
Superfly is offline   Reply With Quote
Old 04-30-2006   #2 (permalink)
kjartan
Any chance you could post the full procedure? I may need to do the same thing, but don't have a manual. Thanks.
kjartan is offline   Reply With Quote
Old 05-01-2006   #3 (permalink)
elr658
Eddie Lawson is God!
elr658's Avatar
You have a bent valve.
1982 Kawasaki KZ1000R1 #658
1983 Honda CB1100F Blue.
www.myspace.com/79cb750f
Old 05-01-2006   #4 (permalink)
neigh421
FELL OFF THE KICKSTAND!
when i do my 87 600rx i just turn the cam lobes away from the rocker arms and adjust them at .009 and .007 i think is what clearance they call for, or i at least go to the most clearance allowed in the manuel because mine always seem to tighten just a little.
neigh421 is offline   Reply With Quote
Old 05-01-2006   #5 (permalink)
Superfly
Superfly's Avatar
Well, the Clymer manual left a little to the imigination! Not a good thing when trying to do timing... adjust valves.. etc... I basically read the whole darn thing, and think (it was very vague in this area) you are supposed to turn the enging over one complete revolution, then everything lines up perfectly so you can adjust the valves (kind of hard to adjust a valve that is partially depressed!)
Anyone have a service manual to check this out?
800 Valve adjustment woodchucks800 Kawasaki Cruisers 111 11-13-2008 02:01 PM
valve adjustment question southjersey636 The Mechanics Corner 2 12-21-2005 02:37 AM
Prairie 650 Valve adjustment TrailBuster Kawasaki ATV and Mule 2 07-28-2005 02:41 PM
valve adjustment for a mojave 01 mojavedd The Mechanics Corner 7 09-13-2004 12:41 AM
Valve Adjustment ZX7R yogiaz The Mechanics Corner 4 12-19-2003 10:21 PM
