Old 04-29-2006   #1 (permalink)
Rubline
Turtle Wax Taster
Rubline's Avatar
Default Tach and Speedo 750 VULCAN
Hello all, I have two questions about my 06 Vulcan 750. First, I know the speedo and tach are mounted on rubber bushings for vibration, but how loose is loose. Compared to the speedo, the tach is half again as loose. I brought it back to the dealer and they said "thats the way its supposed to be" it just seems way too loose compared to the speedo. Second question, according to my gps, my speedo is showing 6 mph faster that actual speed. Is this normal to be off by 6 mph? or should I bring it in for a replacement. I know that the speedo isnt exact, but geeze, 6 mph difference?
Comments welcome.
Rubline is offline   Reply With Quote
Old 04-30-2006   #2 (permalink)
Batman
cruisin for a bruisin
Batman's Avatar
Comments welcome.
yeah i have an 87 and its the same way with the tach and speedo being loose and vibrating. ive never checked to see if my speedo if off, but 6 mph off seems like a bit much. good luck and happy ridding
Batman is offline   Reply With Quote
Old 05-03-2006   #3 (permalink)
JIM KITTS
Hello, I Have A 85 And It Is The Same Way, Good Luck And Ride Safe
JIM KITTS is offline   Reply With Quote
Old 05-03-2006   #4 (permalink)
billc5
billc5's Avatar
Default Vn750
Comments welcome.
I had a 2003....same deal....it was off 4-5 mph higher than actual speed..... especially form 35-40 on up.
Hers 2006 HD Deluxe (Nostalgia)
Mine 2003 Vulcan 1500 Mean Streak-Traded
billc5 is offline   Reply With Quote
Old 05-03-2006   #5 (permalink)
zedx11
Banned
you can usually figure the speed to be around 10 to 15% off on the high side. there are several articles out there on this.
zedx11 is offline   Reply With Quote
Old 05-22-2006   #6 (permalink)
REFUGIO
REFUGIO's Avatar
My Tach On My 2004 Vn750 Is Twice As Loose As The Speedo.
Any Way To Tighten It Up A Bit To Be The Same As The Speedo.
2008 VULCAN 1600 NOMAD
REFUGIO is offline   Reply With Quote
speedo and tach cables glassman9 The Mechanics Corner 2 09-05-2005 11:07 AM
