Old 05-09-2006   #1 (permalink)
Whip
Default 1977 KZ1000 Neutral Switch
Hi everyone. My neutral light recently stopped coming on when I'm in neutral. I see by reading some of the other threads that I may need a new switch. The problem is that I can't figure out where it is. I see a wire going into the clutch side cover. Could that be leading the right direction? How do I go about getting at it without messing something up? The bike still starts ok with the clutch in so it hasn't really caused a problem, but I miss the nice little green light on the panel. Thanks very much for the assistance. - Ron
Whip is offline   Reply With Quote
Old 05-09-2006   #2 (permalink)
cudaosix
Guitar nerd
cudaosix's Avatar
Send a message via Yahoo to cudaosix
Did you check if the tiny bulb in the panel burned out first? I know it sounds simple but worth checking to start.
Over 40 MegaFonzies and rising
1980 KZ1000
cudaosix is offline   Reply With Quote
Old 05-10-2006   #3 (permalink)
Whip
I didn't take the panel apart and check the bulb but since I now need to have the clutch level pulled in to start it I figured it must be the switch itself. I just don't know how to get to it correctly. Thanks for the help.
Old 05-10-2006   #4 (permalink)
elr658
Motorcycling's Dr. House
elr658's Avatar
Sprocket cover
1982 Kawasaki KZ1000R1 #658
1980 Kawasaki KZ750H1 LTD
www.myspace.com/79cb750f
Old 05-10-2006   #5 (permalink)
cudaosix
Guitar nerd
cudaosix's Avatar
I always have to pull in the clutch to start. Your going to find 30 years of chain lube build up behind the sprocket cover. Thats a fun mess to clean up.
1980 KZ1000
Old 05-10-2006   #6 (permalink)
ejshotgun
How 'bout a Poke?
ejshotgun's Avatar
Mine is located (switch) on the clutch lever. But as already mentioned I'd check the bulb first.
'77 KZ1000 LTD
ejshotgun is offline   Reply With Quote
Old 05-10-2006   #7 (permalink)
elr658
elr658's Avatar
The neutral switch is located on the left side of the motor, under the sprocket cover.
The Clutch Interlock switch is located on the clutch lever perch.
Old 05-11-2006   #8 (permalink)
ejshotgun
How 'bout a Poke?
ejshotgun's Avatar
Duhhhhhh, Thanks Elor658
'77 KZ1000 LTD
Old 05-11-2006   #9 (permalink)
Whip
Thanks everyone! The neutral safety switch was indeed the area where the problem was. I removed the sprocket cover (it certainly was a mess in there) and found that the wire had come loose from the connector. A quick fix and I once again have my little green light! Thanks, again.
Old 05-11-2006   #10 (permalink)
elr658
elr658's Avatar
I love it when it fixes free!
Old 05-16-2006   #11 (permalink)
wiredgeorge
Vintage Motor Mechanic!
A 77 has a clutch interlock switch? I didn't think they stuck those things on till the early 80s... In fact, I don't recall them on any bike till the J motor came out in 81 but I certainly could have a false recollection since Im am getting a bit senile... hehe
wiredgeorge
Mico, TX
wiredgeorge is offline   Reply With Quote
Neutral issues Billm The Mechanics Corner 11 07-03-2007 10:20 AM
1977 KZ1000 LTD dwell angle knucklesn The Mechanics Corner 7 06-02-2006 12:37 PM
Neutral Switch??? Doug_S_NC The Mechanics Corner 3 06-03-2005 11:48 AM
K133 Travelcade Seat 4 KZ1000, Z1, KZ900 "Easy Chair" Double-Bucket Touring Model Steven Accessory Swap Meet 0 04-15-2005 06:53 PM
03 Prairie 360 4X4 Belt Fault Switch jlively Kawasaki ATV and Mule 2 10-25-2004 06:27 AM
