Old 05-11-2006   #1 (permalink)
olbooker
Default Shifting to neutral problem - 250 Sherpa
I'm having an occasional problem while shifting in the upper gears on this '02 Sherpa/KL250G6. It doesn't happen regularly, but once in a while, it will go neutral while shifting up. Seems to be 4-5 or 5-6. Pulling up again always advances the gear. I never imagined it was possible to go neutral once past 2nd gear.
Hopefully, there is nothing major happening and it is just wearing in... I can hope can't I?
Mileage is right around 600 miles, at this point. Hasn't had it's first service yet and it is planned for tomorrow (Fri.).
Any ideas or has anyone else experienced this?
Thanks
olbooker is offline   Reply With Quote
Old 05-14-2006   #2 (permalink)
olbooker
Any ideas at all? On any cycle transmission... Am I looking at pending failure or is it somehow possible to go neutral by not shifting all the way into an upper gear?
Old 05-16-2006   #3 (permalink)
Johnny O.
Turtle Wax Taster
Johnny O.'s Avatar
I wish I could help ya but haven’t come across this one yet. My post is just to bump you up and keep it where other peps can see your question.
OBTW do you have a service manual?
Trailers are a sickness. Ride it!
http://www.hoverspot.com/242585
Johnny O. is offline   Reply With Quote
Old 05-16-2006   #4 (permalink)
olbooker
Thanks for the reply Johnny. No manual yet... I want to buy some riding gear first and then I do plan on buying a factory manual. I did change the oil last Friday (first change) and so far it hasn't happened again. I did notice 6th gear was a little stiff going in once, this week. Other than that, it seems to be behaving for now. I just don't understand how it could go neutral at that point.
I do have an old Elsinore that is disassembled. Maybe I'll take a look at the trans parts for some understanding... probably isn't too dissimilar from the Kaw.
Old 05-18-2006   #5 (permalink)
wiredgeorge
Vintage Motor Mechanic!
I hate to make guesses because I have no idea what a 250 sherpa is. Is this a motorcycle? If it is, or has a motorcycle type transmission, there is little that could cause your problem in the transmission itself. It is more likely in the external shift mechanism. The shifter moves two arms, called PAWLS which grab pins on the shift drum. Neutral is just another pin and on older KZ900s/1000s, this pin is oriented at 8 oclock on the shift drum. The only way, a shift to neutral could occur from one of the top gears is if the shift pawls were bent a bit or the spring that pulls them towards each other were not springing. These pawls have little fingers on the ends that catch the pins and just rotate the drum. It isn't possible to normally rotate from 4th or 5th to neutral as those pins are not adjacent to neutral so the most likely thing is that the pawls are just sort of skipping over the necessary pins and grabbing the neutral pin. To look at this mess, you will need to take off the engine cover on your bike's right side that has the shifter going through it. On a bike, you also have to remove the inner sprocket cover but under that, you can easily see if the shift pawls are bent or the spring that keeps them pushing towards themselves is broken or something. I had a problem like this once when using the incorrect shifter return spring... this is the spring that goes over the shifter itself and causes it to bounce back up. The normal Z1 or KZ900 spring has three loops where the shifter passes through. The spring I used was identical except it had four loops. This spaced it out about 1/16" too far and the pawls would just grab the correct pins sometimes and sometimes would miss and grab the wrong pin and shift into neutral... Make sure they look at the external shift mechanism when they do the 600 mile service. Oh yeah, up in the corner of the external shift mechanism is a keeper that keeps the drum locked in place. It is shaped like a boomerang and there is a spring that returns it after a shift so a shift can only go one position on the drum. If the spring is missing or the mechanism is buggered, the bike could shift as yours does (false neutrals).
wiredgeorge
Mico, TX
wiredgeorge is offline   Reply With Quote
Old 05-18-2006   #6 (permalink)
olbooker
Hey George... Thanks for the info. I'm going to wait until I have a factory manual before digging into this. The previous owner had flipped this bike (on his motor vehicle test ride) and damaged the LR turn signal and the left foot peg. Possible this might have caused some damage. So far, it is behaving, but today it didn't seem to want to shift from neutral to first once in a while.
BTW, the Super Sherpa really is a motorcycle... a dual-sport.
1997 Vulcan classic 1500 Shifting problem Jesus Rivera The Mechanics Corner 4 05-20-2008 09:02 PM
Eliminator 250 overheating problem DAX Kawasaki Cruisers 14 08-08-2006 09:33 AM
Shifting to neutral tandt Kawasaki Cruisers 23 04-29-2006 02:12 PM
Eliminator 250 overheating problem DAX The Mechanics Corner 0 08-01-2005 05:35 PM
Ninja 250 Shifting Simon The Mechanics Corner 3 07-21-2004 09:58 PM
