Old 05-28-2006   #1 (permalink)
zedx0011
Default Valve cover removal ??
Hello...
I am a newbie to the bike mechanic world and need a little help...I need to remove the valve cover on my 94 ZX-11...I noticed 3 cables running perpendicular to the valve cover...I imagine clutch/throttle/choke cables. Is there a way to disconnect them easily, so removal of the valve cover can be done ??
Thanks !!
zedx0011 is offline   Reply With Quote
Old 05-29-2006   #2 (permalink)
E.Diane
Sit speling cheker
E.Diane's Avatar
The choke cable, you can probably just pull on to get enough slack to get it off. If not, unscrew the one of 4 bolts in the top of the carb that holds the bracket.
The throttle cables, on the other hand, are going to be difficult to get off without popping off the bank of carbs. It is for me, anyway. You can probably get enough slack by loosening the adjusters in the cable then you can unseat the sheathed end of the cable from their little seats which will give you enough slack to remove the cable ends from the cam that operates the butterflys. For me, it's easier to take the carbs off and do it because getting the cable ends back in the holes they go in is a royal pain and will cause a lot of swearing.
I have individual K&N pod filters and no airbox so my bank of carbs comes off in about 40 seconds so rather than mess with the cables, I just leave them connected and take the whole rack of carbs off to get stuff out of the way.
...Diane
E.Diane is offline   Reply With Quote
Old 05-29-2006   #3 (permalink)
QKENUF4U
AZ's Official Mechanic
QKENUF4U's Avatar
actually you should be able to get enough slack to not unhook anything but if not then just undo them at the bars
QKENUF4U is offline   Reply With Quote
Old 05-29-2006   #4 (permalink)
Superfly
Rippin Ninja's heads off!
Superfly's Avatar
Sometimes it is just easier to unhook them. I have spent 30 minutes trying to save 15 minutes!
Superfly is offline   Reply With Quote
Old 05-29-2006   #5 (permalink)
Ericthejet
Forensic Bug Splatter Analyst
Ericthejet's Avatar
Slacken off the throttle cables enough to lift them from where they sit at the carbs. You can do this without pulling the cable from its connection on the carb, just at the end of the sheath. Yes you can force the choke spring out and will be able to remove the cable end. Use some spray lube on the choke cable end.
You will not need to undo anything at the handlebars.
1984 Ninja 900 (A1)
To make it go faster I need to add more lightness!
Ericthejet is offline   Reply With Quote
How do you get a water pump cover off an EX500? Fixion The Mechanics Corner 9 09-11-2007 01:45 AM
reed valve removal grandpawmoses Kawasaki Cruisers 4 05-30-2005 08:41 PM
Need Side Cover 1997 Vulcan Classic D2 model mcgalinmd Accessory Swap Meet 0 05-08-2005 07:37 PM
chrome drive shaft cover dickwol Kawasaki Cruisers 3 09-22-2004 02:20 PM
valve adjustment for a mojave 01 mojavedd The Mechanics Corner 7 09-13-2004 12:41 AM
