Old 06-02-2006   #1 (permalink)
Sparkadelic
Default 80 KZ750 sprocket cover removal, etc.
Need to get new sprockets and chain. I took the small plate off of the main cover and there is a threaded stud coming out with nut, etc. What is that and do I simply remove the nut and snap ring, etc.
I obviously have the 4 other cover bolts out and the shifter off. I can see that is going to be a bit sticky to get out (off of the shifter stud). Ya so that is where I am at. What is that behind the small cover and what to do with it.
O ya, The 4 indicator lights between the gauges.
Top - Neutral
2nd down - high beam light?
3rd down - oil pressure?
bottom - brake light
Why would my brake indicator light be flashing? I never checked to see if the actual brake light was flashing..... but it had done this once before for a day and then stopped. It started again yesterday and is still doing it. Kinda weird patterns, when I accelerate moderatly hard it stops flashing. When I cruise, it flashes steady about 1 flash every second or two. sometimes though it does 2 flashes pause... then 2 flashes pause... when I brake, the indicator stays on as usual.
Thanks for any insight,
Brad
Sparkadelic is offline   Reply With Quote
Old 06-02-2006   #2 (permalink)
Sparkadelic
got cover off, figured out what I wanted to know. Now just going to get this sprocket off. o ya and remove sway arm or I may just cut chain as the new one I am getting will likely be linked(not getting a factory chain or sprockets).
Valve cover removal part II zedx0011 The Mechanics Corner 4 06-01-2006 06:10 PM
WTS chrome reg cover & horn cover grandpawmoses Accessory Swap Meet 2 08-13-2005 06:34 PM
New Sprocket d1animal40 Kawasaki Cruisers 16 03-22-2005 01:23 AM
chrome drive shaft cover dickwol Kawasaki Cruisers 3 09-22-2004 02:20 PM
KZ750, Starter clutch/flywheel removal? duckfan The Mechanics Corner 2 09-18-2004 09:51 PM
