LinkBack | Thread Tools |
Old Enough to Ride Slower
Just purchased 2002 Vulcan 750 for my wife. Bike had only 1043 miles. I noticed left rear turn signal was not burning. Replaced it with a new bulb. Bulb worked fine with only the switch on. Worked for a short time while riding then burned out. Replaced again and burned out again within six miles from home. All other electrical works fine. Please let me know what any of you think my problem may be.
Thanks in advance Kamafool
2004 Vulcan 1500 Classic Phat II Risers Mustang Seat V & H Straight Shots Kuryakyn pegs |
Some possibilities come to mind for me:
1. The turn signal stalk may be attached too firmly to the bike. Vibration is hard on filaments (ever drop a flashlight?). Perhaps there is a rubber pad where that stalk bolts to the frame, and it's missing on that side. 2. Your voltage regulator may be failing, allowing high voltage. So maybe instead of running 13.5 to 14.5 volts, you're more like 15.5 to 16.5 volts. That will give your bulbs short life, and it's just coincidence that the the same bulb keeps burning out before others do. To find out if this is the problem, just check your voltage while the bike is running. If it's too high, it's time to replace the voltage regulator. 3. Poor contact to the bulb, or in the wires leading to the bulb. This would cause the bulb to flicker when it's supposed to be on. The quick on/off cycles give incandescent bulbs a short life. You didn't describe any flickering, but maybe it happens while you're driving, and you don't notice it. But even a worst case scenario probably wouldn't fail in less than a month. So that doesn't sound like your situation. 4. You got a bad pack of new bulbs. Try a different brand from a different store and all may be well. There may be other possibilities, too, but those are the first things that come to my mind. Curt
red 2001 Kawasai Ninja 250R http://www.curtmorales.com/Ninja (note capitalization) |
Banned
Right on, Curt. I had a bad batch of bulbs once. I thought I was in real trouble. When you try another bulb, make sure to put a little grease on the bulb, and make sure that the re is NO corrosion inside the socket. If you find corosion then take some WD-40 and arag to clean it out completely before installing a new bulb.
| 750 Vulcan rear end tear down & Motorcycle Lift | 2WheelFun | Kawasaki Cruisers | 4 | 09-26-2005 10:04 AM |
| rear turn signal (question) | mumbles | Kawasaki Cruisers | 10 | 09-17-2005 03:00 PM |
| Rear turn signal loose? | BigJohn | Kawasaki Cruisers | 10 | 08-06-2005 01:52 AM |
| 96 Vulcan turn signal problems | Smokedawg | Kawasaki Cruisers | 2 | 04-25-2005 03:21 PM |
| 250EX rear pod turn signal mod? | Dave 96TA | Kawasaki Streetbikes/Sportbikes | 10 | 04-07-2004 04:38 PM |
