LinkBack | Thread Tools |
I have an '06 EX500 that I managed to bend the rim on. (Obvious way on that
I got the wheel OFF just fine (I have previous mechanical experience), but getting it back on seems to be three parts of impossible! The right hand pad fell off when I was taking the rim off, and is being a helluva pain to get back on with the wheel. Now might be a good time to mention that I didn't have a bike jack, so I just sort of laid it on its left side, which was already damaged cosmetically from the accident. So the 'right' side of the wheel and whatnot are the 'top' to me. On my new wheel was a little metal cylinder thingy that gets in the way on the brake side of the wheel. Should that be hammered in or something? I don't even remember it existing on my old wheel. As for the pad, should I just get the wheel on and get the bike upright without the pad on there, and just worry about that while it's upright? Thanks in advance, Jey |
AZ's Official Mechanic
um dude/dudett dont you have a center stand on that bike ???? last ex i worked on had one. you could have just jacked it up off the exhaust.
anyways, get a service manual so you dont go "HAMMERING" parts in where they dont belong. OR put down the wrenches and back away,go find a truck and take it to a shop. |
Clutch Cadet
Sure you even got an EX500 wheel there? I don't recall any spacers being on the right side on the EX, though I think there was one on the left (sprocket) side. In any case, you want to remove it, not hammer it in. The bearings are around there, not a good idea to go hammering around those. If you have both wheels together, you should visually compare them and make sure all spacers and washers that came off the original go back on the new one in the same order, and see what the differences are between the 2 wheels......
#4 (permalink) |
hates stupidity
if you've got an EX500, you have a centerstand, unless you went to a 2:1 header and removed it. ALWAYS use that centerstand when you're pulling the back tire off.
ZedX 1k owner. henceforth The bike shall be Zed. |
#6 (permalink) |
hates stupidity
put bike on centerstand, use a floorjack under the oil pan with a 2x4 to prevent damage, and lift it up. thats how I did mine.
#7 (permalink) | |
#10 (permalink) | |
I wasn't Speeding Was I?
2001 500R Calgary, Alberta, Canada. |
| 1993 EX500 Drum to disk brake conversion??? | z289t6 | Kawasaki Streetbikes/Sportbikes | 3 | 11-20-2006 09:45 PM |
| WTB rear wheel for a 1997 ninja ex500 | pulpz | Accessory Swap Meet | 1 | 08-21-2006 06:49 PM |
| WTB: 94+ ex500 front forks and wheel rim | matty1098 | Streetbikes Buy/Sell/Trade | 0 | 06-24-2006 11:45 PM |
| Couple questions (EX500) | Pilot_guy | Kawasaki Streetbikes/Sportbikes | 9 | 06-14-2006 12:42 AM |
| Steel Brake lines for 87-93 EX500 | xsilverguyx | Kawasaki Streetbikes/Sportbikes | 3 | 01-22-2005 10:05 AM |
