Old 02-11-2007   #1 (permalink)
sikninja636
boost
sikninja636's Avatar
Default 06 ninja 636 exhaust valve?
anyone take theres off? If so pros cons? And I also wanted to know if there is anything that needs to be done to bypass the ECU?
Thanks
Brandon
sikninja636 is offline   Reply With Quote
Old 02-21-2007   #2 (permalink)
GREENISBEST
Honest it wern't me !!
GREENISBEST's Avatar
You can remove the Exhaust Valve which is usually done when replacing with an aftermarket system.
You will need to fit a plate to the controlling motor that the cables are attached to to enable the ECU to see both open and closed stops otherwise the EFI will pop a fault code, This in itself is not a worry but will mask any other fault that may occur and show via the EFI light.
The plate will come with the replacement exhaust in most cases as the manufacturers know it is needed.
As regards just removing the valve from the standard system and running without it, Besides having to stop up the resulting holes you will notice a loss low down but not having carried this mod out i am unsure just how much the bike will be effected.. I can see no discernable gain from that particular exercise
GREENISBEST is offline   Reply With Quote
Ninja 250R Custom Supertrapp Exhaust TeeCat Kawasaki Streetbikes/Sportbikes 5 01-22-2007 11:06 AM
Exhaust Valve on 05' 636...where do i put it? kawa05ZX6R Kawasaki Streetbikes/Sportbikes 6 11-06-2006 01:05 PM
Exhaust for 05 636 05ninja636 Kawasaki Streetbikes/Sportbikes 16 08-02-2006 04:25 PM
Can't remove exhaust valve double stroke Kawasaki Motocross and Offroad 14 07-08-2006 10:52 AM
Need help choosing exhaust for Ninja 636 blue_streak The Mechanics Corner 3 01-06-2005 10:43 PM
