LinkBack | Thread Tools |
I have a 1980 Kawasaki KZ250. After adjusting the valves, I was putting the bolts into the valve covers and I stripped the threads in the head for the hole that the bolt goes into. How do repair the threads?
brian |
KZ geezer
![]() Join Date: Aug 2004
Hi brieweb and welcome to the forum. Timeserts are probably your best bet:
http://www.timesert.com/
1983 KZ550 LTD-M1 (shaft) 1981 KZ1000 CSR-M1 1989 Corvette coupe |
#4 (permalink) |
Vintage Motor Mechanic!
While they may be a lot better than Helicoil, they are also many times more expensive. I use Recoil inserts because of their function and reasonable cost. You will need 6mm inserts. These come in "kit" form. Any insert kit will contain a tap for cutting a new threaded hole. You will also an install tool for putting the insert in the hole. Some insert kits will also give you a drill bit for pre-sizing the to-be-threaded new hole and of course, a handfull of new inserts. Again, 6mm inserts and no more than 15mm length of so. The kits will have inserts in different lengths depending on the manufacturer. I would spend the money on Timeserts for plug thread but not case screw/bolt hole repair.
wiredgeorge Mico, TX |
