Oil Light
+ Reply to Thread
Results 1 to 3 of 3
Thread: Oil Light
  1. #1
    Join Date
    Mar 2007
    Posts
    2
    Default Oil Light
    I just bought a 2003 zx-6rr. It has 5500 miles on it. Last night I changed the oil and filter. This morning I started it and the oil light was on. I double checked the oil level and it was a little high. So I drained some of the oil and it is now correct, but the light is still on. Any suggestions?
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #2
    Honest it wern't me !! ULTIMATE Forum Supporter GREENISBEST's Avatar
    Join Date
    Nov 2006
    Location
    Northants UK
    Posts
    2,432
    When you changed the Oil & Filter last night did you start it up then and did the oil light go out if you did ??
    Did you use an OEM filter ??
    Did you prime the filter first ? ...Not that it's usually needed on that Model.
    When the motor is running does it sound different EG knocking noise ??
  4. #3
    Join Date
    Mar 2007
    Posts
    2
    I got it. I didn't let it run long enough. Thanks.
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. in the mail - Vulcan 2000 Oil Level Check Procedure
    By Spok in forum Kawasaki Cruisers
    Last Post: 11-05-2008, 11:19 AM
  2. oil and temp light wont go off
    By arty0021 in forum Kawasaki Cruisers
    Last Post: 06-02-2006, 11:06 AM
  3. What brand and type of engine oil are you using?
    By uf-engineer in forum Kawasaki Cruisers
    Last Post: 03-07-2006, 09:20 PM
  4. Oil, oil every where!!
    By tnhunter in forum What I learned today
    Last Post: 10-16-2005, 09:12 AM
  5. oil light on after oil change
    By SPINNY in forum The Mechanics Corner
    Last Post: 05-26-2004, 11:43 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
