Old 03-14-2007   #1 (permalink)
Army_of_Ninja
Army_of_Ninja's Avatar
Send a message via Yahoo to Army_of_Ninja
Question lil problem with my 636 and coolant...
Ok... lets see how best to explain... the lil window that shows coolant level says i'm on the low side but when i open the radiator cap there is fluid to the top... i removed all the fairing pieces and when i looked under the gas tank i noticed a coolant cap on the i guess you would call it the reserve tank maybe? Now when i start my bike and let it idle for about 10 minutes in 68 degree temp outside within that time it the bike gets up to 144* and steadily climbs 145 146 147 148 i shut it down after it got up to 170. Now i dont know if just adding some coolant to the reserve tank would help this problem or if i'm seeing symptoms of a more serious problem. Such as water pump failing or somehow the system is plugged? The bike is an 05 ZX6R with 9057 miles on the odometer. The bike has been laid over and the stator cover was cracked which resulted in a oil leak. This is being replaced tomorrow my question i guess is... will adding coolant to the reservor do anything about the rapid climb in temperature? Thanks for any advice or help you guys/gals can give i'm anxious to get my bike back out on the road but i dont want to do more damage by rushing it and causing even more damage in the long run.
No one is more professional than I, I am a Non Comissioned Officer a leader of Soldiers.
www.msf-usa.org
Army_of_Ninja is offline   Reply With Quote
Old 03-14-2007   #2 (permalink)
2006ninja500r
2006ninja500r's Avatar
After you start riding does the temp drop?
If I just let mine idle it will steadily climb until the fan kicks on, which is over 200.
Ben,
My Bike
Black 2006 Ninja ZX6R
Old Bike
2006 Red Ninja 500r
2006ninja500r is offline   Reply With Quote
Old 03-14-2007   #3 (permalink)
zedx11
yellow doesn't corner wel
zedx11's Avatar
Send a message via Yahoo to zedx11
that is the reservoir, the radiator will be full unless the recovery system isn't working.
my bike has gotten up to 220 or so in last summers heat.
Darrell
Ignorance is a disease my friend. You should rid yourself of it.
zedx11 is offline   Reply With Quote
Old 07-04-2007   #4 (permalink)
LRod07
[/u][/i][/b]
hi i have read several posts and have seen the bold and underlined word several times and im just curious what is that. can someone please help a newb
LRod07 is offline   Reply With Quote
Old 07-04-2007   #5 (permalink)
serlant
Who am i?
Send a message via MSN to serlant
Google is you're friend Stator
Originally Posted by Wikipedia
The stator is the stationary part of an electric motor or alternator.
So its the alternator cover i think.
serlant is offline   Reply With Quote
Another question for a '04 ZX-6R 636... TEMPERATURE ninja636-2004 Kawasaki Streetbikes/Sportbikes 3 11-29-2005 07:27 AM
2004 ZX6R 636 Coolant Question southjersey636 The Mechanics Corner 1 06-25-2005 10:45 PM
