Old 03-26-2007   #1 (permalink)
CommanderCool
Default Trouble with '04 Ninja 500 rear tire/brake
I got new tires and brakes put on my bike in the last couple months and I've started noticing recently that the rear tire is rubbing against the rear brake (or disc) in certain areas. About a week ago I had it up on the center stand to lube the chain and when I was turning the rear tire to move the chain I could hear a small scraping sound in certain areas. Is this something I should take back and have it looked at or is this a quick fix I would be able to do myself? It just sounds like either the rear disc or the rear brake is loose, I wouldn't want to take it back to the dealer just to have that looked at.
Also, it has no noticeable effect on performance. The only time I can hear scraping when the bike is in motion is when applying the rear brake, but it still works just as well as it did before.
I could take pictures of the problem area if it would clear up any confusion.
Any help would be greatly appreciated.
CommanderCool is offline   Reply With Quote
Old 03-26-2007   #2 (permalink)
taro
Wants better weather!
First of all, welcome to the forum. I've got an 04 ex500 too and I also hear a scraping sound when the brake pad hits the disc in places through the revolution of the rear wheel. It just rubs slightly and my rotor and brake pads were fine, so I haven't worried about it too much. I've noticed it for awhile too.
That being said, I'm no expert and I'm in the same boat. So I'll wait to see what the ones in the know say.
taro is offline   Reply With Quote
Old 03-26-2007   #3 (permalink)
CommanderCool
Thanks for the welcome.
Well if you haven't had any long term effects then I guess it doesn't really matter. I assumed it was going to be one of those things where a year later my wheel falls off and I think to myself that I knew I should have fixed that.
Old 03-26-2007   #4 (permalink)
zedx11
Banned
the brakes will rub a little, it's called brake kiss. the brakes lightly rub the rotor so there isn't much room for the brakes to move before they start to work.
zedx11 is offline   Reply With Quote
WTB: Kawasaki Ninja 250 or 500 Phoenix/Tucson area integrajoey Streetbikes Buy/Sell/Trade 1 11-12-2005 10:57 AM
Is 2003 Ninja 500 a good bike? PupChow Kawasaki Streetbikes/Sportbikes 7 11-01-2005 11:29 PM
ninja 500 wheel help curtissays Kawasaki Streetbikes/Sportbikes 3 10-12-2005 12:06 PM
Regarding Ninja 500 I5-FLYER Kawasaki Streetbikes/Sportbikes 10 09-21-2005 03:43 AM
2005 ninja electrical trouble heather Kawasaki Streetbikes/Sportbikes 4 08-02-2005 02:47 PM
