I have a 84 454 LTD that I am bringing back from the dead. I got it up and running over the weekend after the requisite carb cleaning. There was some frightning thick black varnish in there, but it's all gone now and things look ok, albeit a bit flat on the throttle.
Anyhow, one thing I noticed on the carbs when they came off, is that between the carbs in the front, near the tops, is a sizeable black plastic tube. It has a large nipple on it as if a hose should go here, but I dont see any loose vacume hose on the engine. This tube would feed into the backs of the main diaphrams so I assume that there should either be vacume here or its just a relife tube for the diaphrams? One last detail is that it is located about where the throttle/choke cables link up to the carbs. Thanks for any help! I am a bike carb newbie (used to old Holley's and Edlebrocks) -m |
Ebay Monkey
It's probably just a ventilation tube for your carbs, and used to have a line leading ( where... back to the air box i think... ) you can check the parts diagrams at http://www.buykawasaki.com ( under owner info - parts diagrams ) and look up the carbs to see for sure what that part is called / for, but as long as you don't feel any suction there when the bike is running, you should be okay.
1984 ZN1100 - Tank issues :/ 1989 EX250 - Bodywork? what bodywork? 1973 CB350G - bits in boxes |
really needs his bike D:
![]() Join Date: Apr 2006
It's an overflow/vent for the carb. Moreso a vent than an overflow, though.
Some bikes have a clear tube running to this fitting, others don't even though most parts diagrams usually show a tube running to it. Nothing to worry about at all. Mine didn't when I pulled my carbs for the first time and I was in the same mindset as you.
1995 Candy Red Ninja 500 *R.I.P.*1997 Peacock (LOL!) Blue Vulcan 500 |
#4 (permalink) |
Ebay Monkey
... That's what i thought. But my mind wasn't really working very well yesterday, is all >_>
| GPX750R - carb question? | qzak | Vintage Motorcyle Info | 10 | 04-09-2008 05:43 AM |
| One more Carb question | deadseasquirrels | The Mechanics Corner | 7 | 12-31-2006 10:25 AM |
| '89 Ninja 750 Carb Question | Glaxtx | Kawasaki Streetbikes/Sportbikes | 3 | 06-29-2006 03:16 PM |
| Newbie question re 2004 Classic Carb versus 03/05 Classic FI | scharfg | Kawasaki Cruisers | 14 | 11-22-2004 10:15 PM |
| 90 EX500 carb question | 71_307 | The Mechanics Corner | 1 | 09-15-2004 02:00 PM |
