Old 05-01-2007   #1 (permalink)
vashfaye
Question 1982 Kawasaki GPZ 550 Electrical won't work!!!
My 82 GPZ 550 is having some weird electrical problems. No lights anywhere, but it will start. No pinched wires anywhere that we can find. When we open the fuse box, the fuses are good. If we jump the main fuse to any of the other fuses (Bridge it) all of the lights go on and work. It doesn't make much sense. We can't figure it out, we have other friends who aren't sure what is going on with it either. Please help!!! Want to ride this season. (Not very long season in WI either)
vashfaye is offline   Reply With Quote
Old 05-01-2007   #2 (permalink)
zedx11
yellow doesn't corner wel
zedx11's Avatar
Send a message via Yahoo to zedx11
can you post a picture of how you are jumpering the fuse box?
Darrell
Ignorance is a disease my friend. You should rid yourself of it.
zedx11 is offline   Reply With Quote
Old 05-03-2007   #3 (permalink)
vashfaye
When you open the main fuse box, there are 3 fuses. One is for the starter and is directly connected to the battery. the other two run all of the lights. When i take a pair of channel locks and touch one end of the fuse for the starter, to either of the other two fuse ends, the appropriate lights work. I'll try to get a picture. can't get in the garage to get one.
Old 05-03-2007   #4 (permalink)
vashfaye
http://www.buykawasaki.com/DefaultFr...OSEVEHICLE.ASP
zthis should take you to a list. Click on Chassis Electrical Equipment. The ref# you want to look at is 26001D It should be a picture of 3 fuses. 26006 Is the main fuse attached to the battery, the other 2 are the lights. Hope it helps.
Old 05-03-2007   #5 (permalink)
vashfaye
You need to search for the bike. This is what I entered: Motorcycle-1982,550,all, all-Choose GPz Sportbikes Click view parts diagram. That will pul up the list I told you about earlier.
Old 05-03-2007   #6 (permalink)
Roofgunner
Turtle Wax Taster
test the fuses. they may look good but not be good. Like some women, and not to offend them, some men. check all grounds, too.
Roofgunner is offline   Reply With Quote
Old 05-05-2007   #7 (permalink)
QKENUF4U
AZ's Official Mechanic
QKENUF4U's Avatar
ya just have to do some testing with and ohm meter to see where the electri stops and where it starts....get you wiring schematics and it will show you the paths the electricity takes and you should be able to do test till you find the dead wire/wires
QKENUF4U is offline   Reply With Quote
Old 07-02-2007   #8 (permalink)
SkyShannonGPZ
GPZ rider til I die
SkyShannonGPZ's Avatar
I had a fuse a couple weeks ago look brand new (well, it was) but the top of it, that you can't see because of the chrome end cap, wasn't connected. Could be the same thing.
1982 GPZ550
SkyShannonGPZ is offline   Reply With Quote
Old 07-02-2007   #9 (permalink)
OKC_Kent
Can't find time to ride
OKC_Kent's Avatar
For a quick check (if you don't have any new fuses); wrap the fuse in some aluminum foil and see if the lights work. If it does then you have a bad fuse. You can also use the foil wrapper from a pack of cigarettes. (this trick has got me home at least twice)
Kent
Oklahoma City, OK
'78 KZ 650 B2
'83 KZ 750 LTD F1 Shaft
OKC_Kent is offline   Reply With Quote
Need Service Manual For 1982 550 LTD Hoomgar Accessory Swap Meet 3 09-26-2008 05:29 PM
Kawasaki can make you sick. Uncle Bob Off Topic 20 08-12-2008 10:47 PM
Front Cowl and Starter 83 GPZ 550 DonaldP Accessory Swap Meet 0 05-09-2005 10:44 AM
Kawasaki 550 LTD Woes Hoomgar The Mechanics Corner 4 03-22-2004 11:01 PM
Parts Microfiche or PDF or Whatever for 1982 LTD 550 Hoomgar Accessory Swap Meet 2 02-29-2004 05:20 PM
