Old 05-14-2007   #1 (permalink)
stevend135
Can't find time to ride
stevend135's Avatar
Default Replacing a head gasket
Hi, I found out my headgasket and base gasket are leaking, I saw smoke and oil slowly coming out and little air bubbles. So how hard is it to replace these would it be best to take it to a dealer or get a shop manual and do it my self?
thanks
2000 Kawasaki Ke100 (seized engine)
1994 Suzuki Katana 750(sold)
2002 suzuki sv650 naked
stevend135 is offline   Reply With Quote
Old 05-14-2007   #2 (permalink)
YurFatMom
Jedi master
YurFatMom's Avatar
Are you doing this on a 2 stroke?
'03 YZ250
'03 Kodiak 400
'05 YFZ450
I turned blue!
YurFatMom is offline   Reply With Quote
Old 05-14-2007   #3 (permalink)
stevend135
stevend135's Avatar
Yeah 99cc 2 stroke.
Old 05-14-2007   #4 (permalink)
WeBeToyz
Make Mine Pure BHP
WeBeToyz's Avatar
Send a message via AIM to WeBeToyz Send a message via MSN to WeBeToyz Send a message via Yahoo to WeBeToyz
2-strokes are relatively easy if you have some wrenching experience. Get a manual and read through the procedure & you should be able to handle it.
Basically pull the pipe, disconnect the carb (airbox if necessary) from the head, remove the head & remove the cylinder. Put rags between the piston/crank & the cases to keep the piston from moving around and getting scarred, and to keep gunk out of the cases when you remove/scrap the old cylinder base gasket. Great time to hone the cylinder & replace the rings if you have some miles on it.
Bryan
'94 ZX-7
'06 Dragon Run
WeBeToyz is offline   Reply With Quote
leaky head gasket burtnboo Kawasaki Streetbikes/Sportbikes 2 03-23-2007 08:01 AM
91 zx6 head gasket prob 400exwlspankyou The Mechanics Corner 13 09-11-2006 10:37 PM
head gasket question on 85 zx600 ninja oldskoolninja The Mechanics Corner 2 09-10-2006 09:51 PM
Replacing Head Gasket on 92 EX500 hwvanmatre The Mechanics Corner 1 05-05-2006 10:55 AM
help !!! having issues with a head gasket ! mikeyzx9 FAQ'S 3 06-13-2005 01:15 PM
