Old 05-15-2007   #1 (permalink)
turpehar
Default 1981 GPz fuel injection for carb swap
I'm looking for some help determining the wires I need to retain after removing the fuel injection for a set of bs34's.
I have disconnected the fuel injector wires and the wires to the fuel pump.
Now I have no spark. I have a shop manual but it's barely readable as it is small and all the lines cross. It gets confusing. I guess I need to find out the wire that send the signal to the ignitor.
Please help
turpehar is offline   Reply With Quote
Old 05-17-2007   #2 (permalink)
turpehar
ttt
Old 05-18-2007   #3 (permalink)
elr658
Motorcycling's Dr. House
elr658's Avatar
Ax the fuel pump.
Ax the injectors
Ax the computer
Install 29 smoothbores with pods.
Go fast.
1982 Kawasaki KZ1000R1 #658
1980 Kawasaki KZ750H1 LTD
www.myspace.com/79cb750f
Old 05-24-2007   #4 (permalink)
turpehar
I'll answer my own question. I pulled the relay completely out including the wire loom going back to the brain. I still had a problem with spark and the starter.
After running diagnostics, I found resistance to be dead on target with specs for the 6 pin plug running up to the starter switch. After plugging the 6 pin plug back together, the starter worked. So I poured some gas to it and it fired, sounding very strong.
For Sale 1981 GPz 1100 in Central Illinois turpehar Streetbikes Buy/Sell/Trade 11 07-25-2007 02:23 PM
fuel injection for 81 GPz 1100 - Illinois turpehar Accessory Swap Meet 0 05-01-2007 11:43 PM
OK I Give up! What Is SeaFoam? msa1956 Kawasaki Cruisers 22 07-22-2006 01:46 PM
Diference between the Fuel Injection Processors RampRat Kawasaki Cruisers 14 06-03-2006 01:21 PM
6r>6rr fuel injection Andreas Kawasaki Streetbikes/Sportbikes 4 05-24-2004 11:58 PM
